What did you do to your Mopar today?
two different styles of door panel clips.
wire, as shown, and sheet metal/spring steel.
not sure when the change over was, but IIRC sheet metal was early, wire late.
Had to shovel 10 inches of snow from in front of the garage door and check the trickle chargers on both cars....This sucks!.....C'mon spring...
I sold my 63 Harley and all my stash of parts. I'm putting the money to good use --spending money on my 68 Satty project like I always wanted to. Hired a body shop to do work that I used to do myself. Got both quarter skins installed, new windshield put in, Now working on hail dents. Ordered: Dynomax Super Turbo mufflers, 4 Keystone classic's, 4 235-60-15 tires, vinyl roof, window seals-fuzzies, carpet, front seat covers, seat foam, ordered new Roadrunner hood today, tomorrow ordering new rear leaf springs. MERRY CHRISTMAS TO ME !!!...........................MO
After a bout with winter weather, I finally got my rear springs and rubber bushings today in Omaha. Also took my stainless trim to be polished and a couple dents taken out. 4 weeks wait on that. Got home and UPS Santa had delivered the new seat covers and foam buns. The foam buns will make the seats look factory new, and be easy to install. The seat covers are from PUI and are top notch . I can't imagine Legendary as being any better. Appointment for truck freight to deliver the new AMD Roadrunner hood tomorrow. ...........................MO
Going to install a hotter set of plugs----------------
Continued stripping the '71 Charger down for paint and checked on the '55 Plymouth at the body shop.
another ballast resistor up in smoke .... orderd the dis. and will use a GM HEI module set up
Not a blasted thing, went over to the youngest’s house. Oh my, the horror! 2017 Chebby.. He laughed & said go ahead get in. Humph, I got in more than 1 Vette & Camaro in “ the day”!
53BC966C-75B9-4EB8-9EE0-D3EC7B94B3F5.jpeg 92D6A2CD-758A-4CFC-9983-3E54763C6357.jpeg BD5A89C7-60D4-4B83-AB84-7E70F1EE98F3.jpeg
Got off of work and grabbed the dog and the GTX it was 63 !!! here on Long Island N.Y.today and overcast but then the sun dipped down bellow the cloud line enough to burn the fog off and brighten up the late afternoon, also stopped by my buddies shop and got the car inspected and he didn't charge me. said it was on the house.
The man in the big brown truck delivered the new 3/8 fuel line, Body line clip set and sending unit I ordered. the cruise was also to try and drive off some of the gas in the tank so I can install the sending unit.
Really killed it today! Garage door stopped 2/3 open, rail needed a little white grease. Left door open to let warmer air in the ice box. Now the car part. Needed to move car 6" to the center of garage. Done. So f in lazy.
New axles from Dr. Diff on the way to compliment the freshened 3rd member.
Mocked up and measured the alignment on my bellhousing.
I'm off .010, so now I'll order some
Offset bushings.
Test fit the manual trans floor pan shifter hump.
Stripped, and DA'ing, evidently some where the car was totally stripped and every inch has been coated with filler ....now I know foe sure!!! I do not want to change careers and be a P&B tech!!! For y'all that do this daily I salute you!
20180217_145504.jpg 20180217_145447.jpg 20180217_145442.jpg 20180217_140214.jpg
Got the gauge cluster back from JC Auto. They did a really nice job. Installed the cluster and trim pad today. Tomorrow the switch plate.
Anybody that's replaced a gauge cluster knows it's almost impossible to secure the pin harness to the PCB; there's just not enough room. So the wife got underneath the dash and installed it for me. Pretty cool. Of course I helped by holding the bezel steady.
