Thank you Threewood. I really appreciate your feedback. My thought was to weld the wheel housing but I wasn’t sure about the trunk pan and extension. I ordered a spot welder so once that arrives I’ll get started!!!! Do you know for spot welding do I have to clean up both sides of the metal surface on each piece to weld?Looks amazing! That should be good to weld the pan, wheel housings and extensions. Before you weld the quarters, get the trunk lid bolted up. Welding new metal into place was my favorite part.
Thank you!!
In terms of getting both quarter panels on so that I can fit the tail panel and the Dutchman panel, is it OK to have both quarter panels removed at the same time? I will have the trunk floor and passenger wheel tubs welded. I’ve gotten and read mixed reviews on removing both quarter panels at the same time. Currently no additional bracing in the car.Looks amazing! That should be good to weld the pan, wheel housings and extensions. Before you weld the quarters, get the trunk lid bolted up. Welding new metal into place was my favorite part.
Personally, I would keep as much original metal as you can and build off of known placement. The AMD Dutchman is known to have issues with fit. You will also want to test fit the rear glass and trim before welding it in.In terms of getting both quarter panels on so that I can fit the tail panel and the Dutchman panel, is it OK to have both quarter panels removed at the same time? I will have the trunk floor and passenger wheel tubs welded. I’ve gotten and read mixed reviews on removing both quarter panels at the same time. Currently no additional bracing in the car.
Thanks again threewood. Unfortunately pretty much all of my rear end is totally gone. Not much to go off of. I was able to line up the new tail light panel with the old drivers quarter Which actually fit right on top of the old one.Personally, I would keep as much original metal as you can and build off of known placement. The AMD Dutchman is known to have issues with fit. You will also want to test fit the rear glass and trim before welding it in.
I’ve been doing some research and trying to figure out what is the best primer/protectant to spray on all of the exposed metal under the quarter panel and around the area of the rear window mechanism? I want to seal up all these areas that rusted through before. Should I use an epoxy primer, metal etch primer or does it matter what kind of primer or use?
Awesome!!!! Thanks again threewood. Prior to epoxy should I use a rust converter for any risidual rust?I would use epoxy primer on everything you can get to with a spray gun. On small spaces where metal comes together like flanges and panel seams I poured Rust Bullet coating into them (like the door bottoms where the skin is folded onto the door frame). Actually, I coated quite a few exposed areas with Rust Bullet and so far so good.
