Badvert65
- 3:05 AM
- Oct 11, 2013
- Brightwood, Virginia
Just put some duct tape on is somewhere and you will be considered a genius for making it work.
Nothing wrong with ceramic disc capacitors. High value carbon resistors could be improved with film resistors.Nice photo 451MOPAR! I wonder if those resistors-capacitors were just upgraded (MILITARY spec!), would it be a killer ignition????
Not to hijack Drew's thread...but I'm interested. Hey might as well ditch all of it, right? Distributors can cause funky issues too. Can you detail what you did in another thread? (Unless of course it's double secret!)I just took it to the next step and got rid of the distributor on my engine.
Glad to hear it Bob! It was good talking to you. Have a good one!Just kickin' in...thanks for that spare wheel, DrewTX! That puppy is now at work.
Nice work fabricating a bracket to mount the HEI module! I'm not sure that it's all that important to look period correct, especially since the HEI module isn't really hidden. It's more important to keep the HEI module as cool as possible and adding an HEI heat sink would be a great addition.Tired of my ignition problems on my 1971 Charger, I decided to make my own using a GM module (I already hear the screams) and an E-core type coil and some bracket fabrication.
To install: mount the collar to the distributor, connect the distributor plug, one wire each to the + and – coil terminals and turn the key! When I turn the key, no more few turn overs of the engine… it fires up immediately! The performance on the road far surpassed my expectations. For a professional install, I used OEM Delphi terminals and my Rennsteig PEW12 hand crimper. I'll never be stranded again, as I can pick up one of these modules anywhere. My collar distributor mount isn't completely necessary and was just to hide it, as I still have my orange box there to look correct. Not bad for $75 in parts for the module, coil and aluminum pieces!
You are right, you need a full 12v constant supply! The bracket is a 1.25” tube bracket for rail or dune buggy.Nice work fabricating a bracket to mount the HEI module! I'm not sure that it's all that important to look period correct, especially since the HEI module isn't really hidden. It's more important to keep the HEI module as cool as possible and adding an HEI heat sink would be a great addition.
Since much of the wiring can be reused if you replace the Mopar EI module with the HEI module, the Mopar ignition module location would be cooler than on the distributor.
I would make sure that the HEI module gets full voltage and I got my relays from Daniel Stern Lighting. I have write-up about my HEI upgrade here: HEI Ignition Upgrade.
Very innovating.....now get the rope....
