44070dart
- 10:51 PM
- Jul 7, 2009
- right behind you
Marked the bearing caps. loosened ring gear bolts. Pictures of gear pattern. Loosen adjuster locks then tried to loosen bearing cap bolts, were they tight! 1/2" drive breaker bar no go, bench would move and couldn't stop it and pull on B bar. Ok, start air compressor get the air wrench and socket out. First 3 bolts came off fairly easy. The last one 4 times waited until compressor shut off at max presser before it broke loose.
This is a 66 open diff and I'm switching to a cone type suregrip can I use 66 bolts or do I need the later bolts with the larger shoulder. Think I have a set but finding them as with most of things I don't use often. Gear pattern before disassembly .011 backlash.View attachment 669419 View attachment 669420 ......
No GM puke yellow compound.Is that curious yellow?
I enjoyed getting together and shooting the bull while working!! Glad to see the parts going to a great guy on a cool project. I am looking forward to coming down and killing a day with you this winter.Yesterday I drove the 68 Satty about 65 miles to fellow FBBO list member Dale and he took the power brake booster, master cyl, and brake pedal etc. off his parts car, so I could turn them in for cores on rebuilt ones. I am going to convert mine from non power drum to power drum. Beautiful day for a drive, and great to have a Mopar friend . You should see his collection of 68-70 B body projects.. drool- drool ! We also compared hood latches and header panels. ....................MO
Whoa, I don't think I'd put pipe sealer on bleeder screws.
Something's not right if they won't seal without it.
...and now you're trusting the sealer instead of the metal.
I put stainless lines on my 73 and had no leaks simply assembling as normal with used OEM and rockauto replacement parts (Wagner or Raybestos brand).
The only thing I noticed was that the passage holes in the rear wheel cylinders were much smaller than those in the cylinders that came off. I'll likely rebuild the OEM cylinders eventually.
...and BTW I went with DOT 5. It still could use some bleeding, but it stops confidently.
I keep saying--- grounds,grounds lol!Fixed my front right parking light/turn signal that was driving me nuts. Turned out that the socket wasn't grounding to the housing. Never seen that before.
Old cars, it's always something.![]()
