m79ded
Sure It has 10.75 compression to be pump friendly, cam I used is in the picture I will enclose: it's cut @ 112 for better street manners since my main goal is street car and I use 1.6 rockers as well a a RPM intake. The heads really do make a wonderful difference. My buddy Tom @ TK Race just cleaned up the heads, port matched the intake and cut the divider down a bit and it was ready. He is doing up a 471 B-engine with the same heads and a bit bigger solid cam. Last one he did made over 650 on both sides and very streetable. Also he did a 465 RB engine and that thing with 452 heads and a Voodoo 60303 cam did 542HP 578 TQ with 16" of vacuum, that engine was so easy to do because the customer had a crank that got messed up bad on a rod journal so he offset groung it to 3.91 and used 6.70 Big Chevy rods and the same 440 2.067 comp height pistons, It was really cheap and goes very well. There are many great combinations you can put together, just keep it to your intended usage and you will be happy. If I would do it all over and not skimp out on $750 I would do the 471. Hope it helps our Mopar buddies.@m79ded Would you share your compression and cam specs?
I’d like to know more. Sounds great.
