Ranger16
I'd bet replacing the radiator will solve your problem. When I bought my Road Runner in '14 I had the same problem. After replacing the 190° thermostat with a 180° and adding a fan shroud, the problem disappeared.
Mine dropped right in as well.I installed a 3 core Champion and it had all of the factory mounting points to the rad support and the shroud. Dropped right in.
I’m using the Edelbrock 1/4” rubber spacer with 2 gaskets and down to a 2 3/4” tall air cleaner that barely clears the hood. If the new radiator and vapor breaker doesn’t help I guess I’m getting a thinner filterPhenolic spacers are a huge help for boiling in the carb.
Got a 650 brawler with Edelbrock dual plane intake.Are you using an Edelbrock carb on a cast iron intake? If so, just switching to a Holley or Demon carb with phenolic bowls may solve your dilemma. An aluminum intake may help as well.
Yes I did. I had to drill new holes in the plastic shroud to align with the radiator attachment holes but otherwise it fits great.The warmer the engine the better its efficiency. I run a 180 thermostat as it's a compromise between 190 and 160. If I recall correctly, Holley videos on YouTube say fuel should be halfway up in the sight glass. That's where mine were set at the factory.
Did you install your fan shroud, yet?
Glad to see you're making headway.
yup. On the money.FYI, the fan should be half in and half out of the shroud.
I’ve used to plumb it to a regulator, but have heard that one of these 3 port fuel filters is being used with success by some.How are you guys terminating your return lines up front? I have used the original style vapor separator with 5/16 in and out, but would prefer to find an alternative. I will be running 3/8 supply from the tank and either 1/4 or 5/16 for the return.
