mr. b
welded in right front frame rail and inner fender on the road runner
wow...an 85 GLH Omni didn't think there was any of those left! good for you for keeping that alive. I put a bushing in the right side lower control arm on the fury and drove that for the first time this year, than sunday did a t stat in the challenger and took that out for a ride....spring is creeping in here in jerseyGot my 1985 Dodge Omni GLH out,put a clutch in it.Clutch was smoked good wore down.I get it out,anyone that sees knows GLH stands for goes like hell
I have had it for 2 years.I even drove it to work today,I outran a Mustang with it.wow...an 85 GLH Omni didn't think there was any of those left! good for you for keeping that alive. I put a bushing in the right side lower control arm on the fury and drove that for the first time this year, than sunday did a t stat in the challenger and took that out for a ride....spring is creeping in here in jersey
Sometimes doing things yourself is easier than you thought.Got tired of waiting for additional hands, so I installed the rear bumper alone. Turned out to be one of the easiest things I've done on the car.
Except installing a gas tank....that SUCKS alone!Sometimes doing things yourself is easier than you thought.![]()
Go to put gas tank in my 65 OOPS, put a sump in center where strap goes. So cut strap just before sump. Buy 1/2" square tube cut two 8" pieces weld cut strap from front of car to square tube. At each end of tube add a strap to get past sump. Weld on second tube to the two straps. Then weld back strap that goes to rear of car, the right length. After that crap the tank install wasn't so bad.Except installing a gas tank....that SUCKS alone!
Jeff
You just need a good box as a helper...Except installing a gas tank....that SUCKS alone!
Jeff
Nice!You just need a good box as a helper...
