Ernie ingling
Appears block heads not cleaned after machining any grit in oil pan along with bearing material?
So i have a bad oil pressure in my Charger, hooked up a mechanical gauge but still bad, got a tip to change oil + filter, but i think i will change the oilpump when i'm at it.
Is this the way to go, what would you do?
Could use some more information. How many miles on the engine? What is the oil pressure cold?, and at temp? Most of the time I have found it to be worn cam bearings. Running a heavier oil, say 20W50 will help for a while.So i have a bad oil pressure in my Charger, hooked up a mechanical gauge but still bad, got a tip to change oil + filter, but i think i will change the oilpump when i'm at it.
Mains usually don't have much to do with oil pressureNot good.
Maybe the main bearings have too much clearance.
Hopefully an engine builder here can give you suggestions.
I can assemble one but certainly no master machinist/engine builder.
with your train of thought might as well change the motor while your at it. Just change the oil and filterSo i have a bad oil pressure in my Charger, hooked up a mechanical gauge but still bad, got a tip to change oil + filter, but i think i will change the oilpump when i'm at it.
I can't believe you did a rebuild and didn't replace cam and cam bearings, lifters and oil pump? If your gonna do it why go half the way and as you are finding out doesn't save money in the long run.
When I rebuilt mine I installed a used cam and lifters. Mine has run perfect for 22 years. So I'll disagree with that statement.I can't believe you did a rebuild and didn't replace cam and cam bearings, lifters and oil pump?
I don't see how this is helpful.Why would you take it apart if it ran well? If it ain't broke, don't fix it. You can't get proper parts anymore, so leave it alone!
My '75 Road Runner is under restoration. I completely disassembled it. The body work and paint are done. The interior is done. Both are gorgeous! The 400 4 Barrel runs just fine, so I will leave it alone! I have replaced the valve cover gaskets and the pan gaskets, but nothing more. I am replacing the external accessories and repainting it, but that's it! It will continue to run just fine for many years to come.
The TorqueFlite 727 also works fine, so I will leave it alone. I have replaced some external seals that were weeping and the pan gasket, but nothing more. It worked fine when it came out of the car and it will continue to work fine for years after it goes back in.
Modification? Why bother? What, will that get you to the show faster? Would that make your car incorrect or non-numbers matching? Yes? Then why do it? That shatters resale value!
Bottom line: again, if it ain't broke, don't fix it. Of all of my car guy buddies, those who have no troubles are those who left it alone! Drive your car, maintain it, enjoy it and leave it alone. If you will just maintain it and leave it alone, it will serve you well for many years!
Dave
Did you read post #70? Let me share another scenario. When my racecar engine was 1st built the short block was used. The bearings were new. Mains were .0037-.0038" rods (BME aluminum) were .004". Oil pressure was only around 40psi going thru the lights. Pump had the adjustable relief spring full tight. After a few passes it was pulled down and .001" bearings installed to tighten up to .0027"-.0028"M /.003"R. What did that do for pressure? Absolutely nothing. Eventually tracked it down to pushrod feed being too large. Restricted them and after turning the adjuster screw full loose in the pump pressure was still to high. Ended up cutting the relief spring a 1/2 coil 3 separate times. The pressure is now 70psi@7000. Plenty of spots for oil to leak internally in a engine causing lower presure. But bearing clearance seldom bothers pressure anywhere but at idle. Idle pressure means nothing. Pressure is no more than a measure of resistance to flow. Flow is what is important.Save your time and money on an oil pump change. Oil pressure is determined by rod and main bearing clearance, not the oil pump!
