cbodybob
- 12:55 AM
- Jan 10, 2014
- youngsville, NC
Actually have a friend who owns his own appliance repair business. I ran this by him. He said it handles water temps up to 140 & more psi than the 8 I’ll run in my drag car. He said it bends easily & last years. Decades. Failure rate is low. Can’t imagine 140 temp to be an issue. But I agree I’m skeptical but Uncle Tony is the man. Lot of tips from his years of experience drag racing.PTFE lined is what i'm using on my 64'. Ive been told to be very careful about not letting it bend to hard because it may pinch closed inside and you wouldn't see it. That being said, is pvc the same thing as PTFE?. I wouldn't chance it. I know it was popular for awhile to use red pcv fuel lines on open hood hot rods but guys got away from that because they went bad after only a year or two. Also i don't think pvc has the same resistance to heat. It's kinda like the plastic in-line fuel filters that you see hanging over some peoples engines, ya, they sell them but...
You’rePVC is not the same! Please dont use toilet bowl water line on your car! Unless your a complete idiot then i guess your going to do it!
Nope Tony DeFeroNever heard of him but my first impression of 'ol uncle Tony is he must be a dipshit.
Yes, that's what i'm going to use on my current project. Years ago i use the rubber/ braided steel line on my 31' coupe and with the tank in the trunk it got a little sketchy with the fumes. Felt like the car should have had a hull blower system like on a boat ,lol. Changed it out to a Ptfe line and problem gone.PTFE and PVC are different animals.
PVC- Polyvinylchloride
PTFE- Polytetrafluoroethylene
I installed the PTFE lines on the Charger, a little tougher to work with than the steel braided rubber lines. Try and avoid really tight bends and you should be fine. PTFE is impervious to the ethanol in our fuels today, where the rubber lines will swell up like a pig. Bonus on the PTFE..no more fuel smells in the garage
PTFE is the generic term for teflon invented by Dupont. I work in the Chemical Industry and can tell you Teflon this the most Chemical resistant material Sold! Yes very expensive but it is the best and has very good solvent resistance.I checked a chemical resistance chart for PVC and gas will have a "moderate" effect and states "caution advised". I'd pass on that.
Cut those off. In my post I said UT said AN fittings fit it fine. He even demonstrated how to properly cut them offAnother problem with the washing machine hose is the hose washers and hose connectors. They are not a tight compression or flare fitting. I would be very concerned about leaks from the ends.
Read my post first. I cleared this up right from the start.I don't know whethwr to laugh or cry !!!
