What did you do to your Mopar today?
After alot of madness with the RR this long weekend it needed a wash and thats what it got, and the purple hornies makes every living thing turn their head:usflag:
If your fuel filter is really up to doing its job, the carb should still be getting clean gas.
Supposed to be a good filter. Lost of small crap in the bowls. Can I use brake cleaner to clean the carb? Nevermind, I found some old carb cleaner. May have to also use a little brake cleaner. First time taking a carb apart. Wish me luck.
Went for a drive in the Power Wagon Then cleaned and readied all parts to assemble my 4-speed tomorrow.
View attachment 954757 View attachment 954758
When I first got my Road Runner running after it sitting for 17 years, I put TWO filters on it, one before the fuel pump and one after. I STILL got a very fine beige silt in my carb. After needing to get towed back once from it, I had enough, I replaced my fuel tank and had no more issues.
I would think you at least need a very good clean out of your tank, or maybe replace it.
Hawk
Changed #7 spark plug, that PB booster makes it a pain. 1 Remove air cleaner assembly. Drop spark plug socket (regular socket won't fit) down tube, 3" extension on 1" extension ratchet wrench. Unscrew plug, remove ratchet ( fun time)remove 3" extension without dropping 1" in the hole. Remove 1" and hold spk plug socket and remove that with sp plug. New sp plug put 1/4" hose on tip put it in tube carefully start threading. Once started remove hose and put plug socket in hole without foam insert, if it stays on plug you'll know why. Now put 1" extension on 3" extension so that 1" extension goes in the tube first. Tighten plug, remove ratchet, now the fun pull 3" extension and grab 1" extension remove 3" extension while holding 1"extension. Pull 1" extension so you can hold sp plug socket. Remove 1" extension and then remove sp plug socket. After all that crap thought maybe a fine cable or fishing line through socket drive and up the outside to make it easier to remove everything, next time. View attachment 941362 View attachment 941363 View attachment 941364
Snap on makes a 5/8' Spark Plug socket ( do not know about 3/4 , 13/16, or 14mm) that has a magnet inside in stead of the rubber. Be careful though so many bought it and broke the magnet , that they do not warranty the magnet. So I crack the plug loose with any socket, the use same extension set up and the snap on to get it out and put it in. Part no. S9706KMAG You can also get extensions that have a square "ball" instead of the round style on the end of the extension. but to get the socket ( or what ever ) off the extension you have to manually push in the square edged "ball" with a pocket screw driver. BUT IT CAN NOT FALL OFF.
Well the laneway has dried out earlier than usual, the gravel road is dry and the town has had the DogF crew out for weeks sweeping the streets of sand, so only one thing to do. It's time for some "essential travel"! Hasn't run since the night of our Daughters wedding on Sept 21st, 7+ months ago. Two taps of the gas and a quick crank and nothing but music!
View attachment 942309 View attachment 942311
I CAN"T hear it!
Hawk
Thanks Hawk.
Basically the same issue. After cleaning the fuel filter and carb out yesterday, I took it for a short ride. (dumb move). It was good until I was a few blocks from home and it started bogging down again. I stopped at my neighbors (chevy guy) to see what he thought and it died. I noticed the fuel filter was almost empty but after a bit it filled back up. Couldn't get it to fire up again. grabbed some starting fluid and it started and died. I'm hoping just the fuel line is clogged but I'll probably take off the fuel fuel pump and clean it out too. Getting a new tank, sending unit and some fuel line ordered. Probably gonna put in 1/2 inch. oh well, another day more money spend on the hobby.
Put a mini starter in my Satellite today seems like it fit ok. Tomorrow going to make sure no contact problem. Touched pos cable to pos terminal quick, no sparks. Guess terminal on starter not touching block. May wrap starter to keep some heat from exhaust manifold off it.
Took me a month But the pink lady is back together. Most of that time was waiting for parts So took time pulling it apart. Saved some work for next winter ( relocate 6al box - it's bolted to inside of firewall, replace interior wire harness and add separate fuse box and harness for all none factory "stuff" and install the heater assembly that was taken out ( nothing under dash at all).
So what I did do was pulled the TCI full comp. 727 Trans. (Cracked a flex plate) and the 4500 stall convertor. Put in An ATI HD 727 (street/strip and 3500 stall which will handle the HP/Torque of my Muscle motors Killer Krate). But this all takes time cause I do it solo on my back (car about 24" off ground so can work over fenders and under car at same time). I Hang the headers with mechanics wire so they can be moved around for clearance other wise have to lift engine. Pull the plugs so I don't break them so I CAN hang the headers. Due to being retired from Auto field I no longer have inspection license so decided to put e-brake back on, sooner or later will run out of people I know to pass it. Found pedal assembly in AZ. got brake shoe strut bar and lever from a member here. I threw those out cause I knew I would never need them. Two new cables easy to find but the L/R came from different B-Body 3"s to short. Do to S/S springs- longer perches and those being weld to inside frame rail (moving everything inboard 3"s - tire clearance, had to make new cable hanging brackets. Perches are where brackets used to be. Made a large S bracket and welded it to outside surface of spring perch. Made my own cable Font to rear cable connector to work. All made so can still R/R spring if needed. While in there new shoes, cylinders, and hardware. Had a caliper leak (have 75 A-Body Disc brake spindle, calipers, and it's 10.87 disc rotor - they fit in O.E. B-Body control arms and do not change suspension angles, attach to B-Body ball Joints). So got two new calipers and pads. I use a 15/16th bore manual (two hole) master cylinder and Wilwood adjustable proportion valve. A lot of climbing under and out from under car, wrong size tool, need different tool. torch to heat bolt, new bolt, etc. etc., Gravity works great for trans. removal but no so much to lift and put in. Have a Harbor freight trans. jack put tranny won't come out from under car on it. So getting back on the jack while both are under vehicle takes some doing. 67 years old so harder than it used to be. To get E-BRK pedal assembly in had to pull seat, as it has a 10 point cage. So it now would really pass inspection ( still know people in industry) put have to apply it with hand, foot and leg won't touch it - cage is in the way. But the hood only weighs 19Lbs. Total and has no hinges so working under the hood is easy.
Humans are the only animal on the planet the works to create more work for ourselves!
Will put the wiper motor/trans. assembly in when I do heater/defroster assembly. OR buy a plug in to power adapter heater for Rebecca's feet and if window fogs she can point it at the window while we drive. Would take pictures, but flip phone won't send them anywhere, and no film for the 35mm.
Changed the spark plugs, washed it, fueled it & drove it.
A lot.
And with much matting of the go pedal.
I really, really, REALLY enjoy this car!
Finally able to replace the original tank and lines. Went from 5/16 to 3/8. Still not sure why the smaller line was used when the sender was 3/8. Reused the original sender and still works perfectly. That undercoating they used back then is a bit crunchy when it gets in your mouth. Took it out for a good cruise. No runs, drips, or errors.
Satellite is back from the paint shop after only 2 months (might be a record).
Putting interior back in and exterior trim back on.
It has to go back for some touch up work and a couple runs but I have to go buy more paint and I'd like to get it color matched.
That means I get to drive it there.
Finished mini starter install. Gave it a quick test sounds nice. Used a mirror to see how close main power stud was from the block, full 1/4". Now those missing power cable brackets.
Finally got the Wilson ported intake on with the 1" tapered spacer.
Definite improvement, with the EMS AC there's about 1" (or less) of space under the hood scoop so it all worked out.
Got the new wheels and tires mounted with an alignment, with new 2" drop spindles.
I'll try another early morning canyon run this weekend to see how it all works out, hopefully I don't mess up the RR or kill myself.
