- 7:26 AM
- Apr 13, 2012
- Granite Bay CA
I'm in a bit of a lull with the project.
I was chugging along at a decent rate and could still be but I decided to pull back a bit. I need a transmission, drive shaft, cooler lines, external cooler, (since the radiator I'm using has no internal cooler) and some type of kickdown linkage. I could forge ahead and buy all of these things but I decided to hold back. I have mentioned this before but to recap: I have a 5 speed manual trans swap planned for my other Charger and when I do that, it will free up all of the transmission related stuff that I need for Jigsaw. I currently have a car up for sale that I hope will fund most if not all of the Tremec 5 speed kit.
I did have a few ideas on what I can do in the meantime.
I could bolt up another 727 and slip the engine and trans in place. This would allow me the ability to get the exhaust system in place. The headers I have are Hooker #5903.
I put Fast Ratio Pitman and Idler arms in so there might be some interference issues. I intend to modify the headers for clearance if possible. I can then pull them back out to sand and paint them with High temp VHT paint. With the engine in place, I can run the wiring, the fuel system, put in the radiator and hoses, etc. Once I get the transmission out of the other car, I can just do a transmission swap in this one and put in all the remaining stuff. Stay tuned, I'll be back with more updates soon. Thanks for checking in!
