- 7:40 AM
- Apr 13, 2012
- Granite Bay CA
I just ordered from them, thanks to you. I was thinking of ordering from Summit again even though their sizes are slightly too large. I was going to get some crocus cloth and try to sand off a bit to get them to fit.Just a heads up on those dowels. I believe Summit sells .500" diameter which is for a Ford. Mopars use .496". I may be mistaken, but you better measure them before ordering another set from Summit. Here is what I always use.
https://www.robbmcperformance.com/products/dowels.html
THIS is a better way, though delivery will take longer.
Regarding the dial indicator and magnetic base:
There are certainly better ways to go. Experience teaches you what worked in the past and what did not. It seems to me that if I was able to start at zero, make a full revolution and have the dial return to zero that the setup is accurate.
