that was a good deal for the machine work
watermelon
			watermelon
I could rig up a momentary switch that temporarily grounds the yellow terminal on the starter relay for starting the car but that would confuse anyone that ever drove the car but me. I do hope to teach the Wife to drive a stick in THIS car!
I'm a bit embarrassed to ask but since electrical stuff isn't my strong suit, How do you test?I'm not sure if Chrysler mounted that switch at the top of the clutch travel or the bottom, either way it can be adapted... Need to test it to see if it's normally open or normally closed... Either can be made to work... It's cheap & being an OE part it'll be good quality..
Ground your solenoid so it works and reverse switch uses the outer two wires on that 3 wire plug.
Yellow is + from key switch, Brown is the neutral safety ground wire. So if you're going to add a button or pedal switch. A wire from ground, to switch, out of switch to solenoid where the Brown wire is. If you use switch at pedal up, you need a Normally CLOSED (edit) switch that closes when you push the pedal and it comes off the switch (Pedal static holds the switch OPEN, so it can't start). Most limit switches come with both a NO and a NC contact to use.With the ebay switch, I guess I could run a ground through the switch and back to the spade terminal on the relay ? Is that a yellow or brown wire, I forget...
my recommendation is the that you find an original 1970 safety switch and install it.
I have this. I have mainly used it to test battery voltage.
I have fumbled through many things with cars but never had a knack for electrical stuff.
If you use the setting with the arrow pointing to it, connect the leads the meter should beeeep, connect the leads to the wires coming from the switch when the contacts are closed the meter will beep..
