So forgetting for a moment about 1 Wild R/T's (whom I respect a lot, by the way) post below, clutches I am familiar with need the throwout bearing to not touch the clutch. This has nothing to do with a slipping clutch. This ensures that when you are not using the clutch that the throwout bearing is not constantly turning and wearing. It only turns and engages once you push the pedal a little bit (by the way, this is why you shouldn't rest your foot on the clutch pedal when driving and not clutching). As you push the clutch pedal, it will engage first the throwout bearing that will then start pushing in the clutch and disengaging it from the flywheel.
OK. I am not familiar with these. On our old cars what I said is appropriate. I admit that I do not know what Kern's new transmission and hydraulic clutch requires.
I 100% agree... And when I first heard of Y/O bearing being in constant contact I expected to be changing allot of bearings... Hasn't happened.. But when you think about it as long as the pressure plate isn't being depressed the bering isn't under any load it's just spinning....
Kern, I guess the bottom line is you should check the manufacturer and be sure it is set as required. It is cheap insurance now to ensure trouble free operation!
Hawk
