- 5:43 AM
- Jan 29, 2018
- Midland Ontario, Canada
Really feeling like Spring out there today...
I did that last year, but one of the "Soup Can Kids" and his Civic Still couldn't keep up. Maybe this year for him I will do just one bank, instead of every other one in the firing order.All you need to do is rip out 4 spark plug wires to make it a 4 cylinder and you'll be fine!!!![]()
. Ongoing series of misfortunes starting with my daily driver.. a Chevy Cruze. The Cruze got put on a scanner, the technician said it was time for a new head, got it rebuilt and whoops looks like it was #2 piston rings instead, said piss on it and proceeded to drive it into the ground then the transmission goes out! Switched to driving the truck, went out to get in it and the tire had a huge hole in it, having no other option I jumped in the Charger and enjoyed a wonderful ride to work
. I get off work looking forward to another nice cruise but just as I hit 70 on the freeway I hear what sounds like pebbles bouncing off of the bottom of the car then no power steering? Fortunately I was close to an exit and pulled off just as it hit 210 degrees, popped the hood and found this.. those were ball bearings hitting the bottom of the car! I'm sure there's less than 10,000 miles on this serpentine setup!I had a similar thing happen to me a few years ago when three vehicles went down due to various issues (blown engine in one, transmission failed in the other, a deer ran into the third and crushed the side of the car). Of course, it was winter so I wouldn't use the Road Runner with the salt on the roads. It is not fun!I broke mine. Ongoing series of misfortunes starting with my daily driver.. a Chevy Cruze. The Cruze got put on a scanner, the technician said it was time for a new head, got it rebuilt and whoops looks like it was #2 piston rings instead, said piss on it and proceeded to drive it into the ground then the transmission goes out! Switched to driving the truck, went out to get in it and the tire had a huge hole in it, having no other option I jumped in the Charger and enjoyed a wonderful ride to work
. I get off work looking forward to another nice cruise but just as I hit 70 on the freeway I hear what sounds like pebbles bouncing off of the bottom of the car then no power steering? Fortunately I was close to an exit and pulled off just as it hit 210 degrees, popped the hood and found this.. those were ball bearings hitting the bottom of the car! I'm sure there's less than 10,000 miles on this serpentine setup!View attachment 1082269
The good news..
The idler was sitting on the frame rail so at least it's only a $15 bearing to fix it.
I just got done shortening a driveshaft for a friend who owns a wrecker service and didn't charger him for it, he returned the favor![]()
I plugged the truck tire (would have preferred to have the tire removed and a patch plug installed) and the bearing to fix the Charger will be here todayI had a similar thing happen to me a few years ago when three vehicles went down due to various issues (blown engine in one, transmission failed in the other, a deer ran into the third and crushed the side of the car). Of course, it was winter so I wouldn't use the Road Runner with the salt on the roads. It is not fun!
Good luck with the repairs and getting back on the road!
. The Cruze on the other hand has pissed me off bad enough that I've got the local salvage yard looking for a 1.4 Cruze with a standard, this POS will cough up the body parts to fix the other then get scrapped!
Yes CoronetDarter it is.......it's this stuff.That came out nice! Is that rattle can?
