biomedtechguy
Accelerati Rapidus Maximus
- 11:18 PM
- Mar 28, 2014
- South Louisiana
THIS!the new (Bill Mitchell Products) castings are supposed to be even better
No joke.Hey, thanks, i'll check these out. Looks promising.
Lookie what I got pictures of this evening!
Not only did I buy my block through Southeast Performance, but he sold me a good bit of the parts that went into my Roadrunner already, like the Viking triple adjustable rear shocks, USCT frame strengthening parts, my Dakota Digital RTX series gauge system and the modules I added to it, and more.I think good practice is to purchase your block through the machine shop you’ll have doing the final machining.
from me, since:
Nice. How big a stroke can that block handle and still be internal oiled? Only reason to get the Indy Maxx block would be if i wanted the short deck.This is the direct quote regarding what additional machining is required:
"these only need lifter bores honed to size, line hone mains, deck and bore"
So that answers the OP question, but I wouldn't consider any of that "fixes before it's ready to assemble". Seems like very basic machining that is involved with any build.
Bill Mitchell Products (386) 957-3009How big a stroke can that block handle and still be internal oiled?
Bill Mitchell didn't know how much stroke could be used with this block and retain the internal oiling. I did call Indy as well about the Indy Maxx block and they claim up to 4.500 stroke retaining internal oiling. The bill Mitchell block comes with bushed lifter bores and the Indy does not. I found a Bill Mitchell block for $5400, quite a bit less than the Indy at $6500. I can also get wedge motor mount on the BM block if i want. I use one motor mount on pass side to locate. Thanks guysBill Mitchell Products (386) 957-3009
Post the response so we can have it here as a point of reference.
Let us know how the call goes. Bill sounded like an old friend when I spoke with him.
I don't think so at this point, but he told me he had some coming in this month. I will be calling him next week or maybe the week after and at least get an order in.Does Bill Mitchell have blocks in stock, or is there a substancial wait for them ?
He is at the point, according to my builder, where BMP is going from filling pre-orders with $500 deposits to stocking blocks for sale, at about 30 units per month. I'm not sure how that 30 breaks out, Hemi, RB, small bore, big bore, etc. I can say if you want an aluminum block, BMP has them, for real, not "Coming Soon" or "New and Improved" vs "Almost Unusable"....Does Bill Mitchell have blocks in stock, or is there a substancial wait for them ?
I put 4.500 stroke in stock 440 blocks with internal oiling all the time using 2.200 journals and H-beam rods and a Bridgeport. The BMP should take it no problem. I don’t think I’ve ever used internal oiling with an Indy block so I’m no help there. Forget the wedge mount idea, it’ll just be a header nightmare. Put a torque strap or a motor plate on it. If you’ve got cash to burn, buy the KB block. Good luck.Bill Mitchell didn't know how much stroke could be used with this block and retain the internal oiling. I did call Indy as well about the Indy Maxx block and they claim up to 4.500 stroke retaining internal oiling. The bill Mitchell block comes with bushed lifter bores and the Indy does not. I found a Bill Mitchell block for $5400, quite a bit less than the Indy at $6500. I can also get wedge motor mount on the BM block if i want. I use one motor mount on pass side to locate. Thanks guys
Why the KB block?I put 4.500 stroke in stock 440 blocks with internal oiling all the time using 2.200 journals and H-beam rods and a Bridgeport. The BMP should take it no problem. I don’t think I’ve ever used internal oiling with an Indy block so I’m no help there. Forget the wedge mount idea, it’ll just be a header nightmare. Put a torque strap or a motor plate on it. If you’ve got cash to burn, buy the KB block. Good luck.
Because once you go down this road it just leads to wanting more. You start out with a tunnel ram and a couple carbs and the next thing you know it’s got a screw blower and it’s on methanol. The KB will take more power than any of the rest.Why the KB block?
FWIW, the BMP blocks are already in use at the 2,000 HP plus range. Bill probably knows more specifics, but when I asked him when they were switching from nodular iron to billet steel caps, he told me that there were nodular iron caps on his blocks that were putting out over 2,000 horsepower. It wouldn't matter to me, and I only see one possibility regarding increasing the power on my 541. I let the builder know that I do want to be able to make use of the Nitrous Express 2bbl spray plate system. Rated at 50-300 horsepower, I would probably jump in at 150 and that would be after I get a handle on the ponies I have already. It may be that I can only use it in the last part of the track, but if I need a fender and I get a half a car length, that works.Because once you go down this road it just leads to wanting more. You start out with a tunnel ram and a couple carbs and the next thing you know it’s got a screw blower and it’s on methanol. The KB will take more power than any of the rest.
some may say 700 ft lbs is going to be hard to wrangle.
I admit, that's me. I've asked the forum if they could give me an idea of what it's like, and had some good replies, but I'm sure no words can substitute for the experience. I guess the closest I've come is somewhere in the low 500 ft lbs range, based on stock torque values vs lightly modded.Wrangle? Sounds like that was spoken by someone who never had 700 at their finger tips or should I say foot.![]()
