- 2:30 PM
- Mar 28, 2014
- South Louisiana
YES! Thanks, again for your reply!well you've seen it before Bio but here it is again, 720ftlbs@4400 at 3800lbs
I remember it seems that you were working on improving track times.
I'm liking the daylight under the front tires, and I've had subframe connectors, torque boxes, and leaf spring mount reinforcement plates all welded in to prep my Roadrunner for that. Strange Engineering took care of chromoly steel everything from the slip yoke to the pinion yoke, 1350 solid U-joints, caps, driveshaft, and a safety loop in case any of that should fail. I have to see what kind of roll cage is required based on time and speed, but I'd imagine a 4 or 6 point would be required. I may do that after the engine goes in. The Passon 855 has been promised to take 700 ft lbs continuous torque, and I've been told that is conservative. McLeod RXT dual disc clutch was recommended by McLeod, and they are aware of the HitMaster launch control, thus the 1,000 horsepower rated RXT vs the 700 HP RST, because the friction material is ceramic/metallic in the RXT vs organic for the RST. The clutch is broken in, and I believe my issues I was having with it behaving as though it was not fully disengaging seems to have resolved itself.
Here's an article on a "Torque Monster" build Hot Rod Magazine covered with Indy Cylinder Heads years ago, and it is a coincidence that the displacement is basically the same that I've planned at 541 cu in.
https://www.hotrod.com/articles/mopp-0004-plymouth-roadrunner-torque-monster/
