Curiousyellow71
Some of the aftermarket rods use bolts instead of studs, That would be the easiest to identify, I would focus on identifying the rods.
I am going to take some pics and videos tomorrow and rely on the experts here to help out!Some of the aftermarket rods use bolts instead of studs, That would be the easiest to identify, I would focus on identifying the rods.
550-600 hp with cast iron manifolds is going to be difficu
Yeah, I know. I‘ll have to cross that bridge later. I really dislike headers.550-600 hp with cast iron manifolds is going to be difficult
Do you need just better all around pics of the pistons or trying to find markings? I will look again, but I did not see any markings other than an "O" and the directional mark for installation.It's a stock bottom end with new pistons.
The better the piston pics, the better we might be able to identify them![]()
Yes mainly any markings on the bottom of the piston head.While I have the oil drained, anything else you think I should be looking at?
Basically, you will never break a stock rod, no matter how shitty you think they may be. (Not sure why you came to that conclusion)I looked up the rod P/N (1851535, I think) and it looks like OEM. Hopefully the guy didn't use the same rods that were in the motor to begin with. Ugg.
Keep in mind that I know very little about 440's. I have always been a Chevy fan so I appreciate all the comments. There are always little tricks and in the know type knowledge that you guys have. Just trying to get into the groove.Basically, you will never break a stock rod, no matter how shitty you think they may be. (Not sure why you came to that conclusion)
As I mentioned before, you can take any bone stock crappy junkyard 440, and put those little blowers on them , and they'll be happier than a pig in poop. Or put a 250 shot on them, they don't care. Seen it many times.
No need to create a new reality.
Worst case scenario ; melt the corner off a piston from incorrect fuel mixture. Which is ten times more likely with a boosted program.
Thanks for your input.Yes mainly any markings on the bottom of the piston head.
The nut end of the rod bolts too.
Wow, 8300... Your talking a big block right?With that nice scope...Pull a plug out and look at the top of the piston.
Oem rods are not bad, mopars were all forged, not cast like most gm rods. I'd rather run a factory set then "cheap" chinese set, but past 600hp we run eagle and scat rods. If it has a light pistons that helps them considerably. They likely have been gone through...better picture of the rod bolts would help.
We ran 550-600hp with stock rods arp bolts for years. Even went throuh the traps a couple times at 8300. We have pulled one in two that even had arp bolts....but a cylinder wall was split. Likely any rod would've let go.
Here are some more pics. Thanks for you help.Yes mainly any markings on the bottom of the piston head.
You should be showing a pair of pliers hammering in a nail!
