Runcharger
Really looks like a stock bottom end. Depends on the pistons but if they're lighter than stock it'll take quite a bit of abuse. Other questions are how far in the hole the pistons are? Windage tray? Oil pan?
I've broken 440 rods but that was using 1000 gram pistons and buzzin it to 6500.
This is starting to look like it would be worth bolting on a supercharger and sending it to me. Run the heck out of it and if it breaks then you can spend all the cash on a rebuilt shortblock with some tricks. No need to bust it down now. I would however get a shot of the tops of the pistons (try to rotate one so it's at TDC). I would also make sure it has a baffled oilpan of decent capacity and a windage tray, you can change those in the car BTW.
