'68 Coronet R/T
I sent them an email yesterday, still waiting for a response.
Odd that many places offer complete seal kits for the heater box and not one of them thought to produce the now 55 year old seal on the vent.Unfortunately, that seal is not reproduced.
I don't think that seal was designed to be replaced. I believe the part # for it is the flopper and seal as one. It is really bonded to the metal. I always blast the door and just tape off the rubber before painting.Odd that many places offer complete seal kits for the heater box and not one of them thought to produce the now 55 year old seal on the vent.
Mine was in pretty bad shape. I tried removing it thinking I could repair it but that didn't work. And you are right, it is really bonded to the metal. I even used 3M adhesive remover but it didn't seem to touch it.I don't think that seal was designed to be replaced. I believe the part # for it is the flopper and seal as one. It is really bonded to the metal. I always blast the door and just tape off the rubber before painting.
No, I have had some spare boxes in the past and robbed the doors from them when I needed something better. Start a wanted thread, I bet someone on here has one they would sell.Do you have a source for the flapper and seal part?
I think the way to accomplish carving the contour into the foam would be to create a jig that guides a cutter & the best way to cut foam is with a hot knife...I tried to keep it but the old pad was such a mess, especially after hacking all that hard, brittle vinyl off, that I couldn't get it to look uniform.
I tried to find a close up of the repo dash pads showing the step, but most only give you distance shots of their products.I think the way to accomplish carving the contour into the foam would be to create a jig that guides a cutter & the best way to cut foam is with a hot knife...
But honestly it looks great without the contour so as usual I'm over thinking it...![]()
If you'd like I can get you close up detail shots off mine... It's an uncracked original..I tried to find a close up of the repo dash pads showing the step, but most only give you distance shots of their products.
Yes, that would be great. I try to keep a folder with photos for referencing when needed.If you'd like I can get you close up detail shots off mine... It's an uncracked original..
