Coop
I’d take a look at the results from engine masters on motor trend television. Spend a couple of bucks on a subscription to stream it. It’s well worth it and you can do all the watching you need to in less than a month. They did an episode specifically on easy cylinder head upgrades for the 440. In the end, the trick flow 240 cylinder heads achieved about 540 foot pounds of torque and 525 hp on a very Street able build. The other heads that it was compared to included a redone side of 906 oem heads, a set of 440 source stealth aluminum heads , a set of Edelbrock heads And of course the trick flows that outperformed the closest competitor(edy) by 25hp. They are the most expensive, but I can say I’ve used them on several engines before and the results have exceeded expectations every time. You can start with a proven combination like the one on engine masters and then make tweaks to camshaft selection, as well as compression ratio to get the exact performance you’re looking for. I’m putting together a combo based on these heads I have but the engine work is not complete so I can’t share results
