Got a chance to get back on the 518 rebuild after having to put down our 15 year old Husky. First few days were rough but I find that it helps to stay busy. Made a simple stand out of 2x4's to keep it upright and level for assembly.
Thanks Hawk. They're never around long enough. We were very fortunate to have that much time with her.So sorry to hear about having to put down a member of the family. It hurts like crazy.![]()
Making my way across the bottom of the car sanding the final primer coat with 320. Time consuming and tedious but I'm **** so whatever. Then the engine bay and inside the trunk is next, then finally the outside of the body will get wet sanded with 360 and then 500, then paint!
View attachment 1607409View attachment 1607410
I added those. I did those pieces and the front spring hanger sandwich plates. I went back and forth with doing the torque boxes and decided to not do them. Car is a numbers R/T so I didn't want to add obvious things like torque boxes or subframe connectors but I figured beefing up the spring areas wouldn't hurtLooks great! I see the car has the triangular plates welded in at the end of the frame rails & additional pinion snubber plate, which only Hemi cars got, but no torque boxes. What's the scoop?
I did much the same on Thursday just gone, and dropped off a few fittings to the guy repairing my tank. I bought a Holley in-tank pump mid-last-year, and I am having a flange welded in place as well as relocating the breather outlet - so not an easy fix for a DIY job at home. The horse-shoe shaped strengthening ring was used as a template only - a new CNC cut flange will be welded inside & out for maximum non-leakage through the fixing screws. Hoping to collect the tank Monday next week or soon after .....have another Poker Run on March 3rd.View attachment 1607399
Finally have time to pull out fuel tank
Prepping area I’ll try to install next weekend
Where did you buy gas tank?
https://dantesparts.com/Where did you buy gas tank?
Appreciate that Sir, best of luck with the toe!
