62 Belvedere 318 poly granny cruiser (one day i hope)
Since it's 24 degrees out i went to get some antifreeze for the car this morning (it's in the garage so not worried bout it being water right now) And just a FYI.. walmart has normal non 50/50 AF for $10.88 a gallon... which seemed to be a decent deal.
Master cyl swapped, steering column back in.. waiting on the pump to test it.. recurved the dist again.. and.... #7 cyl has a header leak so bad it might as well not have a gasket... so much for $60 Percy gaskets that you can use over and over.. 1 time.. that's a fix for another day, done for now.
Ok.... power steering is on other than the lines... done for tonight though. Belt alignment isn't as good as i would like.. modified it a bit but not enough.. will just pray it doesn't throw belts.. if it does i'll fix it..
This is the bergman kit btw......
Just posting a couple of better pics in case anyone does this kit and needs to figure out the spacers (have to space the pump back off the bracket) Also cut the welded on nut off the lowest bracket that goes to the 2 timing cover bolts so the bracket will go over the back of it..
Looking great! Is that car originally from Ferndale Michigan?
Frankenmuth.. spent it's entire life there. parked in 78 til a few years ago.
Hmmm not sure why the emblem on the back says Ferndale.. gonna look at the original receipt when i get home.
K.. wow i had never thought to look into it.. Seems Masons sponsored racers in this are starting in 1960... and one guy posted that the ramchargers started there... Glad i kept that emblem.. gonna be going back on now :)
That emblem is like gold. Lol. Grew upon that area right off Woodward Avenue. Lot of history behind that emblem and the high and mighty!! Great history.
yeah i didn't know anything bout masons.. i grew up at the 8/van dyke area.. 1 of the mounting pegs is broken off the emblem. Will find a good way to mount it
Went to South elementary 11 mile and mound area. Owned a store on Stephens and Hoover. And one on 12 and groesbeck. Played hockey at Warren ice arena, Fraser etc. remember any of those?
yeah.. that's where i grew up... hoover and stephens was a 7-11 wasn't it? I used to go to the family store bout 2 blocks north of 9 mile, the one with the kegs sticking out the side of the building... Went to centerline though
Here's a member who restores pot metal...
Post in thread 'After Rebadging' After Rebadging
Where did you buy the Bergman kit? I saw 440 source sells brackets also.
I'm kinda bored here (Christmas at home) so I just read your entire thread. I went through a similar situation with my 65 Belvedere. It is waiting for the trim shop to finish the interior and then I can continue with the debugging (24 miles so far) process. I started in 2009 and it should be done in 2025!
I applaud your perseverance and attitude. This can be a maddening hobby but, it is satisfying to resurrect old machinery.
Now, will there be another?
I bought it straight from Bergman.. talked to him on the phone beforehand.. really nice guy. The kit literally has every thing you need other than directions :) not that it's hard.. just didn't know bout the spacers and **** is all. I need to make the belt alignment a little better than put the hoses on still. It got ball freezing cold out and i am in hibernation mode for now.
Nope... This is the last. I'm 54 and guys in my family rarely make it to 60 which i'm ok with :) I mean.. i want 5 more cars but naw.. this one will keep me busy. Once it's to a place where it drives (and stops, brakes are making me nuts) how i want then i will ramp up power, new bottom end... possibly a blower one day (teenage dream.. thinking bout doing it).. and maybe a 5-6 speed.. Soo plenty to play with once i get this a bit more done :)
What's funny is i have had that car i think 2.5 years which feels like i have gotten nothing done at all then i look back at all the rust repair and ****, was more work than it feels like looking back.. when i was looking forward it was a mountain of work :) Only working when i was in the mood helped. I won't do anything if i'm not in the mood, just makes me hate it.
Hey! I was 54 once, 20 years ago!
Soo.. had one day of nice weather (60 in late december... wtf... ) wouldn't mind all winter being like this though... finished up the power steering and went for a quick test drive.. Steering works good, no leaks and is actually a bit lighter than i expected, it feels like my 66 new yorker did. Although the car does wallow around like a fat pig on ice.. but that's ok, i take corners slow :) Brakes are much better with the new MC, still not amazing but the pads only have like 10 miles on them, i'm told they will get better when they break in. Also need to get them bled but had plenty of pedal.
Posted this pic on imgur and ate **** for normal hose clamps... didn't know what other ones to get.. Oetiker clamps look like a pain in the ***. Oh.. almost might get a power steering cooler though. that pump gets really hot and most of my time is over 2800rpm.
Not really happy with this motor.. but that's a whole different can of worms.. I really wanna switch out these hydraulic rollers for solids but don't wanna spend the money (plus i think i would have to pull the heads to swap em)
