autoxcuda
Tried firing up new ignition… no fuel.
Replacing fuel pump. Pump rod good.
Cam lobe worn?
Do you think the pipes will smoke a bit and darken when you fire it up?this might be a little OCD but i waxed / polished my entire exhaust system , headers , crossovers , mufflers and pipes and tips . then I did the same to the fuel tank.![]()
Finishing up the front bushing change outs. Had some bad rust/corrosion at the inner driver side K member frame bushing. Good friend boxes it and welded it up. Time for an alignment.
Next up: install ECP 26” 2 core aluminum Radiator.
I need to replace these bushings on my roadrunner, this will be my first time doing these. could you give some advice/tips? I bought the Energy body mount bushing kit with 6 bushings not sure if this bushing is included as a body mount Summit part # ESN-5-4111G any help would be appreciatedFinishing up the front bushing change outs. Had some bad rust/corrosion at the inner driver side K member frame bushing. Good friend boxes it and welded it up. Time for an alignment.
