- 10:13 PM
- Nov 22, 2010
- Muroc Dry Lake Bed
Good article and thank you R413!
Only item I have to question in the above in-depth informative article, even though they mention the testing of between 20 and 50 blocks being an adequate size test sample, it was mainly done on I suspect mostly rebuildable "survivor" blocks 50? years old, meaning the discarded/failed blocks over the years are not part of the test sample.Rear this article, very good and dispels the myths
440 Source.com Everything you've ever wanted to know about blocks and more....
Or well designed, and the goal of testing, undermined here again, by only testing a sample of surviving blocks.Many folks have been playing with these cars since new. How many blocks failed on there own because they were a bad casting? Sure there were some, hard to make them all perfect.
Well, good point j-c-c-62...but I am not anything you are saying..it's too deep for me, I appreciate your input. I will rely on the Machine Shop :Or well designed, and the goal of testing, undermined here again, by only testing a sample of surviving blocks.
Again, I am not opposed to testing one bit, but I feel strongly assumptions/conclusions in this matter should be taken with at the least a grain of salt.
I politely disagree with the grain of salt. Please elaborate.Or well designed, and the goal of testing, undermined here again, by only testing a sample of surviving blocks.
That is the point. They only mostly test "good" blocks, the ones that are not able to be tested for whatever reason I suspect tell a story, and we don't know what that story exactly is and our assumptions therefore need a grain of salt.I politely disagree with the grain of salt. Please elaborate.................
That's all they can do.
You are doing everything you can do, and more than most would. I would likely do the same. You will be fine, IMO.Well, good point j-c-c-62...but I am not anything you are saying..it's too deep for me, I appreciate your input. I will rely on the Machine Shop :
1. Have machine shop, in this case Pettis Engineering Hesperia CA check block.
2. Magna flux same block
3. Sonic test same block.
All good...
Using cast pistons, sealed power and standard, not racing equipment...
Again:
IF I wanted huge performance I would install either of these two:
I still call BS on this thinking. You are glass half empty.That is the point. They only mostly test "good" blocks, the ones that are not able to be tested for whatever reason I suspect tell a story, and we don't know what that story exactly is and our assumptions therefore need a grain of salt.
Maybe, but my glass appears here to be a bit larger than yours, as I am asking questions and you are making unsupported and non sequitur claims.I still call BS on this thinking. You are glass half empty.
We as mopar folks are lucky they did this test. They proved there are no thin wall castings, they show the thick web 400's, they tested the iron in different year blocks.
I don't mind repeating that BB Chrysler blocks are not trouble prone, they are good quality even after 60 years of use and abuse.
JCC ought to be a lawyer. He loves to play counterpoint on just about every issue.
A moderator ought to put "Devil's Advocate" under his name here.
I would have said 0.055" over for 4.375" bore because there is a good selection of pistons and rings in that size, but you said it was already 0.060" over.
Only if needed and have it sonic checked to make sure it's thick enough to be safely bored .060.Any thought on practicality/feasibility of doing a 440 .060 over bore? Is it a viable option? I have a 440 block already machined to .060 over bore and was wondering if the block can hold up under normal driving conditions, not "Racing". Essentially a "good street motor". Using cast Sealed Power pistons.
Like this...but I have in my possession:I'll throw out there that if someone is reading this in the future.. go .055 over first. Then you're using the common 4.375 ring package, and leaving yourself room to go 60 in the future..
