SRT8 Roadrunner conversion, NOT a body over!!
Thank you!
Threw the fenders on and bumper to fit the washer bottle. Need to make the surge tank and P/S reservoir bracket, and then calling it done up front. Per Darius, vacuumed A/C system and charged to verify no evaporator leaks. Much easier to switch out now if necessary, but it's good.
Shop is a pigsty! Time to clean up and put up!!
Pretty spiff Craig.
Hey, do we still call that a Monte Carlo bar even though it's not a Ferd ?
Thanks guys!
Not sure on the Monte bar...never heard that before.
Got the coolant tank and P/S reservoir mounted. Keeping it Mopar and used the SRT res and a coolant tank from 2003- Hemi Ram.
What an inspiring build you are a god among builders. Oh yeah. I'm down in Ormond Beach did you ever find a new blaster? I need a RR body blasted and epoxied can't find anyone.
Thanks Guys!
Haven't found a blaster I would recommend. Had a few people tell me that Master Blaster in Orlando can do it, but haven't tried them.
Been buttoning up the million little things. About done with the dash, which means it's ready to fire up and drive on a trailer to the body shop!!
The dash brackets. Starting the upper, forward attachment and A-pillar clearance next. Upholstery guy deals with the finish work.
Incredible work, and right around the corner. Almost unbelievable how easy you make this process look.
Thanks! Your welcome to stop by the shop whenever, just call first and make sure I'm here, as i'm in and out.
Sounds great, runs great, I'm sure it'll be great when done too...
keep on doing what your doing, gonna' be a sweet ride for damn sure
thanks for sharing
Thank you!
Shop is a pigsty! Time to clean up and put up!! i miss my 08,charger srt 6.1,i wrecked it on the freeway i was cleaning the dash in the morning and accidently deactivated the stability traction control..and on the freeway i got cut off and tried to go around the a,,hole,i i gunned it and the car spun out and shot me over to the wal on the shoulder and smashed it so bad that the roof had wrinkles like the matrixx movies,i was ok ,,the charger is a safe vehicle lmao,,i know.anyway nice job and excellent visions of the beast to come.
Hey Craig, sounds like you have a donor car for another awesome build!
