Hawkrod 'RoadKill' Cross Country Trip 2022
I'm not sure if the gods of Arkansas don't like us, but wow. So far we have had ISSUES ever since we crossed over the border!
I guess bad things come in threes? Three issues presented themselves right after we crossed into Arkansas, headed towards Hot Springs:
  1. We stopped for gas and checked the oil. Fine. Great, go to close the hood and it hit the front, upper valance (???) and chipped the heck out of the paint. Somehow the hinge got messed up when we tried to close the hood (?). We had to adjust hinges out in the hot 95 degree sun to get the hood to close. Really?!? Oh well, some more body issues on the poor car...
  2. We decided to drive highway 40 to quickly get to Hot Springs. Well, the rear tire had other ideas. Looks like the belts suddenly let loose. So we ended up on the side of the road putting on the spare while huge 18 wheelers went blasting by us. Then I had to order 2 rear tires. Should be in by tomorrow. $500. Ouch
  3. So we go to pull off the highway and the brake pedal feels funny. It goes (partially) to the floor sometimes but other times works well. We check the fluid but no loss of fluid. Must be the master cylinder. So we found one and bought it. $100
So tomorrow morning we will try to swap out the master cylinder before 10 AM. Then we will drive to a Firestone tire center and get two Cooper tires for the rear of the car.
Yikes! An expensive day, but what are you gonna do???
Dang, that's a rough day! Sorry you're having troubles but i thank you for taking us along on the journey through all the ups and downs. Do we need to setup a gofundme? :steering:
Careful because Arkansas is known for tornadoes.
They don't call it hot springs for nothing...
Thanks, but no; I'm just griping. However, the FBBO network that always seems willing to help is awesome. That is our lifeline!
Haha. We did use zip ties! To put rubber fuel line (cut length wise) over the fuel line along with aluminum foil to try and stave off vapor lock whenever we stop. No pictures yet, but I'm not sure it really helped.. :mad:
Oh Man! When it rains it pours. Hopefully this will be the end of the surprises!
Glad the oil is doing good!
A few bumps in the road so far Hawk....at least it seems to be stuff you can fix up yourself. :thumbsup:
Looks like you'll be blasting right past Sallisaw, Oklahoma.....that's where my A100 came from. :D
Thanks for keeping us entertained with your adventures. :)
When you don't have a bench, I guess this is bench bleeding then?!?
Lots of stuff to unload to get to tools needed. Note also the small spare in the back.
The master cylinder has been replaced. Brakes are good, but we didn't bleed them since we worked hard to minimize bubbles in the lines. I'm sure if we bleed them they would be even better, but we will see if we can do that at the Firestone center when we get tires.
Now to hope the tires come in soon!
Old school ---Try some of the campfire aluminum foil until you find what you want! Put it on loose. It worked at the drag strip in the 70s!!
Thanks for the suggestion - we did try this, although with split 3/8 fuel line first and then aluminum foil. We repurposed an old can to go around the fuel filter.
Unfortunately it didn't seem to improve the hot starting, but it was worth a shot!
Overall though, engine is running well except for the hard starting.
Mercy. Praying you guys have an easier go of it from here on out!
On the carb issue - you sure it's "percolation" that's the culprit?
If so, that big ol' factory air cleaner is quite the heat trapper itself - maybe try a cheap
aftermarket little chrome jobber in its' place and see if things improve?
I read a book about Hot Springs, Arkansas. It was a crazy gangster town.
Gangsters and illegal gambling[edit]
Aerial view of Hot Springs after 1925 along Central Avenue. The base of Hot Springs Mountain is in top right, behind Bathhouse Row. Part of West Mountain is on the left. The southwest edge of North Mountain is behind the Arlington Hotel at top.
Illegal gambling became firmly established in Hot Springs during the decades following the Civil War, with two factions, the Flynns and the Dorans, fighting one another throughout the 1880s for control of the town. Frank Flynn, leader of the Flynn Faction, had effectively begun paying local law enforcement officers employed by both the Hot Springs Police Department and the Garland County Sheriff's Office to collect unpaid debts, as well as to intimidate gambling rivals. This contributed to the March 16, 1899, Hot Springs Gunfight. Of the seven Hot Springs police officers who have been killed while in service of the department, three died during that gunfight, killed by deputies of the Garland County Sheriff's Office. One part-time deputy sheriff was killed also, by the Hot Springs officers.[citation needed]
Along with Bathhouse Row, one of downtown Hot Springs' most noted landmarks is the Arlington Hotel, a favored retreat for Al Capone.[33]
Hot Springs eventually became a national gambling mecca, led by Owney Madden and his Hotel Arkansas casino. The period 1927–1947 was its wagering pinnacle, with no fewer than ten major casinos and numerous smaller houses running wide open, the largest such operation in the United States at the time[citation needed]. Hotels advertised the availability of prostitutes, and off-track booking was available for virtually any horse race in North America.[citation needed]
Local law enforcement was controlled by a political machine run by long-serving mayor Leo P. McLaughlin. The McLaughlin organization purchased hundreds of poll tax receipts, many in the names of deceased or fictitious persons, which would sometimes be voted in different precincts. A former sheriff, who attempted to have the state's anti-gambling laws enforced and to secure honest elections, was murdered in 1937. No one was ever charged with his killing. Machine domination of city and county government was abruptly ended in 1946 with the election of a "Government Improvement" slate of returning World War II veterans led by Marine Lt. Col. Sid McMath, who was elected prosecuting attorney. A 1947 grand jury indicted several owners and promoters, as well as McLaughlin, for public servant bribery. Although the former mayor and most of the others were acquitted, the machine's power was broken and gambling came to a halt, as McMath led a statewide "GI Revolt" into the governor's office in 1948. Illegal casino gambling resumed, however, with the election of Orval Faubus as governor in 1954. Buoyed into 12 years in office by his popular defiance of federal court desegregation orders, Faubus turned a blind eye to gambling in Hot Springs.[34][35][36] Variety explained the status of the casinos in 1959 as follows: "How do these places operate when gambling and mixed drinks are supposedly against the law? Simple. Every week the management appears in local court, pays its fine according to the amount of biz [business] done and goes back to open up."[37]
Gambling was finally closed down permanently in 1967 by two Republican officeholders, Governor Winthrop Rockefeller and Circuit Judge Henry M. Britt. Rockefeller sent in a company of state troopers to shutter the casinos and burn their gaming equipment. Until other forms of gambling became legal in Arkansas four decades later,[38] Oaklawn Park, a thoroughbred horse racing track south of downtown, was the only legal gambling establishment in Hot Springs and one of only two in the state of Arkansas; the other was the Southland Greyhound Park dog track in West Memphis. Both Oaklawn and Southland remain in operation.[39]
By that map, you are headed into NE Oklahoma. That's called the Green Country part of OK. It's also the VERY Native American part of Oklahoma. Hopefully, you can see some real Native American culture.
Most of Oklahoma was set aside as Indian Territory, with the general borders of the Indian Territory being formed in 1834 from the Indian Intercourse Act. It was opened for general settlement around 1890. The "Sooners" were settlers who arrived before this period of official authorization. From 1890–1907 Oklahoma was known as Oklahoma Territory. Oklahoma became the 46th state to enter the union on November 16, 1907.
I worked for a company out of Fayetteville, Arkansas ... The did NOT think the " frozen chicken commercials' on the west coast ( with the Arkansas license plates) were funny AT ALL....LOL
We have our new tires and are rolling. We are at a car museum (more pics later assuming we have coverage).
Now to some more camping since yesterday was an expensive day!
Hope it goes better, that would get old fast...
Thanks for the updates & repairs :thumbsup:
Tyson, by chance?
We are camping near the summit of Mt. Magazine in the Ozarks tonight.
Service is slow, but here are a couple of pics from the car museum:
A 1955 Dodge Royal Lancer with a Hemi. How often do you see one of those?!?
Tomorrow we are going to try and get a hike done.
