Lookie what $5000 buys you....
Jigsaw has brakes !
Can you hear me ??
Yes! The car has a parking brake and 4 wheel hydraulic brakes that work. S C O R E !
Here is a tip: When encountering a problem, be willing to listen to advice from others, even the Wife.
I had the Master Cylinder full. The Wife was in the car on the pedal. She was pressing the pedal over and over and I could not get any fluid out of the rear bleeder screws. I loosened the brake hose connection and it had fluid. I backed off the brake line fitting at the backing plates and had fluid. The bleeders were clean. She had been pumping 10 times and holding while I cracked the bleeders and nothing would come out. This went on for 6-8 minutes.
She said....Why don't you try the front?
Yeah, sure...It can't hurt, right?
The fronts spurted out some dirty brake fluid and a lot of air. I made three passes with each caliper. Fluid got cleaner and the air was clearing out. Also, The pedal was now getting some feel to it. I went to the back and sure enough, it started to spurt out of the rear bleeders. Three times at each rear wheel then back to the front. now at a panic stop pedal slam, the pedal stops halfway to the floor. That is good enough for me!
The Wife....what a great lady!
Even when roached out like this one, these cars are beautiful to me.
Jigsaw sits lower in the front:
And higher in the back:
Despite having original leaf springs.
I do have the torsion bar adjusters backed out though.
I cranked up the torsion bars a bit once I had the car back in the shop.
No, I'm actually going to leave it ratty while I work to get it running. I'll probably drive it around this way until I get ready to paint it. I am likely to retire and leave this state within a year or so. I want to have it driveable for the move. It costs less to transport a car that runs and drives.
When the red car was original color and ratty, I got all sorts of attention. The beat up cars seem to appeal to more people than the finished ones do, at least that is how it seems.
How are you liking that 5 speed ?
