70rcode
My new Lunati solid lifter flat tappet break in Plan was to use the supplied black Moly Lube paste + Valvoline Conventional VR1 10W30 Racing Oil that's Highly rated on 540Rat's Oil Wear Protection Test that stimulates thin oil film performance protection Without any hi ZDDP oil Additives that Reduce the oil's scuff rating....Of course, all of Lunati's warranty Required J Gibbs hi ZDDP "Driven" Conventional Break In oils & additive suppliments test very Low to Lowest on 540Rat's Oil Wear Protection Test !! ....The Cam company Requires the Highest ZDDP ppm content & Rat's Oil Test shows 1200--1500 ppm ZDDP is optimum (VR1=1500 ppm) with > 1800 ppm Dangerous bad ! ....I just want a good, non-eventful Cam break in ! Both cam oil wear "experts" impossibly opposite & incompatible !! How do you guys work this cam break in successfully ?
