I'm getting really frustrated with this motor.
Don't understand what the builder was thinking
as it looks as though he just threw a bunch
of mismatched and junk parts at it. I'm to a
point now, instead of fixing what I have, to
replace the entire top end with parts that
work.
Parts list: (what's in the motor now)
Cam -TRW TP-238
300/300 adv. 230/230 @.050 480/480 lift
Lobes checked, all good, no damage to
lifter bases.
Lifters - Sealed Power HT-976 (new)
Don't know now if these are junk Bleed down
is fast rate. Pumped up, zero rocker movement
with valves open or closed. After bleed down,
rocker movement on 1,3, and 5.
Springs - Sealed Power VS-675
Free height - 2.300
OD - 1.494
ID - 1.08
Installed open - 1.36 (checked, all good)
Installed closed - 1.86 (checked, all good)
Solid Height - 1.28
Wire Dia - 0.207
# open - 236
# closed - 110
Pushrods:
Were 14 (used) @ 2.980/2 (new)
@ 9.317
Now - 16 @ 9.317 (this change quieted down
2,4,6,8 bank).
Stock (new stamped steel rockers)
No stuck or bent valves.
All valve stems even on both banks
No bent rocker shafts (installed with oilers
pointing down and towards the valves)
with visible good oiling to shafts.
Rocker arms installed correctly
Spark plug wires checked
New header gaskets
After reading many posts here from some
very knowledgeable and helpful FBBO
members, I can't help but think the builder
got by as cheaply as he could.
The bill for this build came to $2700, 27
years ago.
I hope the info provided leads to some
sort of solution, or I'm going to scrap
the cam, lifters, springs, and pushrods
and start over.
