What did you do to your Mopar today?
replaced passenger side front floor
1st time in my 19 years of owning my Bee I will be passing on a cruise night because it's just too hot! I will be there just not taking the Bee.
KID
Finally finished sealing the weather strip in trunk. Next step will be a new trunk mat, Take old door weather strips out and replace with new. when the money situation gets some better..
Filled up the gas tank. :grin:
LMAO! Sometimes that,in itself,is a great accomplishment.
Heading out in about an hour to a cruise about 15 miles from my place. It's 92 degrees here in mid-MI,but Sabrina's been running cool in past hot-weather ventures,so I'm not worried. Yes,I will get pics and you will enjoy them. Later,be safe out there tonight.
[temporary hijack]
Cruisin' Downriver? How was that, with the cruise route all busted up? My wife and I skipped this year, figuring it would be worse than the usual 6mph crawl....
[/temporary hijack]
Changed the oil and put in rear pinion angle shims. No more vibration!
removed fender, re-aligned door and striker/latch combo, re-attached fender, discovered a chared wire under hood.
finally removed torsion bar crossmember,got all the floor pan off the drivers side,cut bad metal out of PS inner rocker,removed tranny hump to clean edge so i can re-attach.Made on heck of a mess on my garage floor.
forgot to add that i cleaned all the mice-nest out of the rocker panel too.
[temporary hijack]
[/temporary hijack]
Nope;not the Downriver Cruise-one I'd like to check out sometime. This was at a local burger joint,and there were some fine cars there. That reminds me;gotta get some pics up.
stripped the firewall and pulled the ac/heater box. Gotta find where to get seals to rebuild the box.
[temporary hijack]
[/temporary hijack]
I went! It was pretty good considering the hot weather, the Holiday approaching, and the construction. They had it cleaned up real nice. Traffic was moving, but attendance was way down. Next year should be great with the new road!
KID
Put the side view mirror on, admired the car for a bit
Took the Green Monster out for a spin in the country... not a cloud in the sky, engine rumbling just right. One of the great joys in life.
