I did not know that you had to pre-order them. How much lead time is required?
 Behr
Hey Behr,
Passon introduced the transmission probably a couple of years ago, but has been working through some issues to get them off the drawing board and truly into production.  Honestly, many people are quite frustrated as they feel it has been a lot of talk and promises but no action yet.  Supposedly the transmissions are starting to ship.
Last I heard, the waiting list was like 400 people long.  So how much lead time?  Honestly the answer is I have no idea.  According to Passon, the lead times will reduce quickly until they should become very small.  We'll see...
			Looking forward to seeing how your F.A.S.T. addition goes. Thinking of doing the same on a 340. If you don't mind me asking, what kind of coin did that run you?
Hey Prop,
Don't mind you asking at all, but my answer depends a bit on what you will end up doing.  In my case, the whole FI thing is getting quite expensive, as I am trying to go the "do it right" approach. So:
1) FAST basic kit (without fuel pump kit): ~ $2200
2) Custom B-Body fuel tank from Hot Rod City (with fuel pump and sender): ~$1000
3) FAST computer controlled distributor: ~ $350
4) Fuel pressure regulator - still need but estimate ~$100
5) I am custom bending hard lines and installing AN fittings, so maybe $50.
You can get a FAST kit with lines, fuel pump, regulator, etc. (everything you need) for about $2700.
I had to be dumb and get a custom tank...:icon_mrgreen:
