UPDATE: 9/21/16.
I am reviving this thread.
Now that I've replaced the entire top end of my engine... (see my thread:
http://www.forbbodiesonly.com/mopar...lls-a-fresh-set-of-906s-on-the-ol-440.117561/ )...
I've taken the car out a couple times since the rebuild and she really runs great. Very smooth. I'm tickled.
However, today I decided it was time to beat on her a little bit, so I hit the 4-lane and started wringing her out.
First gear was great, so into 2nd and hammered it again. She pulled great all the way to 5000rpm and then - she fell flat on her face.
She ran out of gas for a moment!
Didn't die, just flat laid down.
I lifted, shifted up to 3rd and waited a couple moments, then resumed a little throttle. She picked right back up and ran uneventfully the rest of the way home.
Now, when I first started it up after all that work, the fuel gauge showed the usual 6.5psi idling.
When I got home today and looked, it only shows about 4-4.5 psi. ;-(
She runs fine normally and even with a little light romping, but when you get serious, she literally goes dry.
Reminder -
entire fuel system is new, from gas tank to sending unit to fuel lines to Carter "hemi" fuel pump to Edelbrock AVS. Even the fuel pump pushrod has been replaced.
Float levels in carb have been checked and re-checked.
Gas cap is vented, even though the tank retains its' factory vent lines as well.
What the heck is going on? I can accept that the carb is undersized (650cfm) but that doesn't explain what is happening here.
She is flat running out of gas when in hammer mode.
Is it possible the sending unit is collapsing under hard suction?
