SM says have backlash at .0005 to .0015 then turn tooth side so b-lash is .006 to .008. My 80k mile gears had .011 and a good pattern. Sooo my plan was set it at.004 then turn tooth side adjuster until I get .010 or .011 b-lash.Fran,remember, set R&P no backlash; then screw in rt.side adjuster for the lash. Have fun, Jeff. Gotta have a little tension on the housing.
Luv the red!!Got the car in the air to change center section. I prefer to pull whole rear than wrestle around under the car. Its been out in the last year put 4.10's in, mistake. About 2 hours I can pull the rear. Think my Chinesium brake drums rub backing plates. Could be 30 years of laying around may have bent backing plates will check that. Will put original drums on but there +.050 now. Put my FBBO decals on.
View attachment 677880 View attachment 677881
View attachment 677877 View attachment 677878
Yeah and how’s that bum shoulder when trying to hold up an impact gun?(ask me how I know)For me it's easier, bum shoulder. U-bolts with an air wrench and a 11/16" rachet wrech for the shackles, bam it out. If I made one of the fixtures I seen a member did so he could use a floor jack. I don't think I'll do another change. That Jeg's assembly stand for $36 was money well spent, bought thru Amazon free shipping.
A lot better than pulling on a ratchet wrench for those 8 u-bolt nuts and 10 lug nuts.Yeah and how’s that bum shoulder when trying to hold up an impact gun?(ask me how I know)
At least you now have room to install the hose,lol.View attachment 681016 View attachment 681017 View attachment 681018 Put rear on sawhorses and made L brackets to keep it nose up. Used 3" muffler clamps to hold L brackets. Only able to bend 3/32" stock, no torch had to stick a block of wood under housing.
Order a lower hose from Amazon, check the box it came in. It was the only item in it. The narrow side facing camera.
