- 6:39 PM
- Jul 17, 2008
- South Jersey USA
note that I was so confident the "crush" repair would be no problem, that I did the *** end rust repair first!
I appreciate your confidence. In matters that I have experience, I am confident too. I always have doubts until my eyes have seen things happen. I have built stuff out of wood that looks right but is out of square AND I have built things that are square but don't look right.
I'm not so worried about getting things square because doing so is easy: I just keep shifting stuff around until the cross measurements are the same. I am curious about the side to side height of the frame rails at the core support. I'm only guessing but maybe the car gets set on a level floor, jack stands even from side to side and the furthest forward section of the frame rails are checked off of the floor before welding up the core support?
measuring off the floor is ok if the floor is level and the car is level, It will get you in the ball park, but no welding is to be done until fenders are on and fitted........ the height at the front of the rail is dictated by: 1) door to fender gap 2) distance from top of core support to hood, ie the height of the hood stops being equal.....
****my #1 tell when reconstructing is my own eyes....... I look across the core support in relation to the cowl, and the bottom of the window openings..... I look thru the car to the package tray and rear window opening...... same thing when looking from the rear, across the trunk opening......... just like looking down the side of a studded wall before it is sheet rocked, an out of plum stud will stand out..... if your corner is drooping, or too high you will see it, it will be obvious. (and your fender won't fit)****
the purple car above had both front corners down hard, driver side over 2 inches, pass side over 3 inches...... that is why i posted it, to show how getting the front corners at the proper height is fairly straight forward, and dictated by the front end sheet metal....... sorry if I'm being redundant, I'm trying to ease your intimidation factor
beat the firewall out from the inside, it don't need much...... I'd probably go as far as cutting the damaged piece of cowl off, beating it straight and welding it back on........
Steering the repair toward the theme set by El Dubb,
Here is an idea: Since the cowl top is curled down at the edge...View attachment 832451 View attachment 832452
What if the panel was cut along that edge..... See the point where the horizontal part of the cowl turns almost 90 degrees into the engine bay? Cut along there, Then going down that black line, remove the spotwelds on the lip leading down to the drain, turning left across that lip....
Then cut vertically up that black line ? The section could be hammered into shape, the cowl top could be straightened as well.
There are some leaves in the cowl that need to come out. This would allow me to get a vacuum hose up in there too.
Was this what you were thinking?
Personally I think I would move the one cut away from the top of the cowl & down to the bottom of that vertical area.. It would require more dolly work to fix the hard line at the cowl but it would reduce the heat going to that flat top area of the cowl..
I added to my post...I think we were typing that at the same time...... great minds lol
I would just replace the rail and inner , maybe both rails, inners, and core support as a unit, just cut everything that's bent off......... the hood and fenders, will dictate everything
