71charger_fan
- 11:11 PM
- Jul 19, 2008
- Frederick, Maryland
I've had intermittent no start issues with the '71 Charger since I got the car back from the shop that worked on it. Today, I was supposed to drive it to PA to let the body shop that's going to paint it see it as the guy they sent to check it out at the house has quit and moved on. Of course, it wouldn't start. Started with the simplest thing first and cleaned the battery terminals. Turned the key, and she fired right up. I turned it off, loaded some stuff in it, then hopped in, turned the key, and nothing. So, in a modern marvel of poor diagnostics, I decided it was the neutral safety switch. So, I went and bought one and realized the wiring was iffy at best. So, my new harness came out of the package and I installed that while I was working on it. Got it all put back together and...nothing. I didn't even have back up lights anymore. So, back in with the neutral safety switch I had just removed, turned the key, and she kicked right over but would not run. After 5 or 6 tries of this, she wouldn't even try to start anymore. I turned the key on and had no power in the ignition circuit either. So, I jiggled the key quite vigorously and it started and ran. Crap.
Off to the attic to get out the spare column and I spent the rest of the afternoon getting the ignition switch out of the spare column. I tested that switch through all of its positions and it tested fine. So, now to find the time to pull the switch out of the car and replace it with the spare.
