747mopar
Great post. Chalk up another reason for me to go solid flat tappet.
What kind of lifters are they, and what is the lift on your cam?
By the way, the CompCams springs and hydraulic lifters that replaced the proven to be weak springs and shot lifters I had in the 452 heads on my 440 have been FLAWLESS in their operation.
My 440 6bbl DEMANDS that it be unleashed to spin up to 6,200 and I have my shift light set at 5,800 and rev limiter set to 6,200 based on what my ENGINE wants, and I have to once again say that the "mystery" purple stripe cam MUST be the 292°/.509 hydraulic. That is the perfect explanation for the performance I get and so clearly feel.
I promise I'll post the results of the chassis dyno runs whenever I can get over there to do that, but I swear my butt dyno is right on.
Those CompCams springs and hydraulic lifters turned my 440 6bbl loose, and instead of the "fire breathing dragon" hiccuping right when it was about to torch the village, after the CompCams parts it's like:
I'd have to go back and look but it's a fairly mild cam, just over 500" lift on the exhaust and just under on the intake with an rpm range of 1800-5800. The lifters are Comp Cam, I'm not real savvy on solid lifters seeing how this is the first ones I've ever ran but they have a pushrod cup with oil feed holes in the lifter body much like a hyd, it would appear that oil softens the noise since it's pumped in under the cup?
Even though it's got an rpm range of 1800-5800 it really likes being shifted at 6,000, well rounded cam for my use.
