- 11:51 AM
- Mar 10, 2010
- Hanover, Pennslyvania
Hi Guys' In my last post I indicated that longer top shock eyes were in order. I wished to gain some rebound (droop) and reduce the bump side travel. The total shock travel was ok but I had it biased toward the bump side not allowing enough droop. As I indicated the simplest solution was to extend the upper shock eye. I elected to machine them manually so they didn't require CNC time and use up favors. The new eyes aren't as pretty as the originals but I was able to do most of the machine work myself. One of my friends at the shop, Tom B did the snap ring grooves, it's a tricky operation with a standard boring head and requires a deft touch not to snap off the .046 grooving tool. We increased the section under the bore radius to make them easier to machine and I felt the with the increased distance between the end of the shaft and the mono ball bore additional material couldn't hurt.
In the location that they're in the vehicle you really can't see them unless you pull the wheel and tire off. I guess I'm getting lazy. If you're getting tired of seeing this project blame Kryslerkid.......LOL......it's his fault, he's the one that said I needed to include more background information. Thanks for looking, Brian.
Hey I'm used to getting blamed for things and I'll gladly take credit!
Looking good Brian. I love machine work and I like seeing good work
