- 7:49 AM
- Mar 28, 2014
- South Louisiana
WOW man! All of that fuel and laughing gas pouring into a HEMI!
IT'S A BEAST!!
IT'S A BEAST!!
---Very nice malex, and wow! Hemi Dart...what a ride!
Looks greatMy Hemi Dart AAR hood is finished. And another poly paint booth job in the books.
Now that the Dart is finished it will get put away in storage in a couple weeks, until fall. When it comes back in the fall I hope to have the hemi ready to go in. Looking forward to getting the 64 back home and a new season to get ready for.
----Looks great
I'd love to have you as my next door neighbor
paint my car, my garage job sucks
As soon as the Democrats move out I'll check into moving in.![]()
Thank you & you're right,
Budnicks is the first to make clear that the D)s are clustered mostly around the big cities. His neighborhood may be mostly R)
For me, the D) control at state level makes Cali a "no go zone" but Budnicks seems to make it work or at least bearable.
you'd be welcomed here, I'm sure----
If I was your neighbour that would be a fun neighbourly project! As soon as the Democrats move out I'll check into moving in.![]()
we just dodged a bullet from sacramento last month in the primarys, dont matter where u r in the state, they want to get rid of prop 13. rumor has it they r still counting ballots towards it from the trunks of cars in alleys.....november they r going to try again. with another bag of D tricks.Thank you & you're right,
we are all pretty conservative in this community
it's nothing like the valley or Bay area
Man you have too much time on your hands ! . Mine is lucky to get motor washed once a year , just a quick wipe over mostly .Still working g on the assumption the tracks will open. Pulled the trans to make a spacer to give the converter more clearance. Found damaged pump rings, shaft, and reaction support. Probably damaged when it broke the ear off the converter and busted flex plate from last year. Replaced those parts along with a new filter. Everything else looked like new. Checked the valve springs and lash. New plugs , cap, rotor. Found the coil terminal had unscrewed itself. Coil wire was just setting on the stud. And since I have all kinds of time the bottom and the engine hit cleaned and waxed.
View attachment 928036 View attachment 928037
View attachment 928033 View attachment 928035
doug I noticed the plates on top of your carb's. did you make those? and why?. I am having trouble with my car throwing fuel out of the carb's. when I lowered the float level I picked up a slight stumble. I was trying figure out how to stop it splashing out. fear of a fire starting is not something I need or want.Still working on the assumption the tracks will open. Pulled the trans to make a spacer to give the converter more clearance. Found damaged pump rings, shaft, and reaction support. Probably damaged when it broke the ear off the converter and busted flex plate from last year. Replaced those parts along with a new filter. Everything else looked like new. Checked the valve springs and lash. New plugs , cap, rotor. Found the coil terminal had unscrewed itself. Coil wire was just setting on the stud. And since I have all kinds of time the bottom and the engine got cleaned and waxed.
