- 10:39 PM
- Jan 29, 2018
- Midland Ontario, Canada
Reverse light switch on the transmission.
Thank you Dadsbee!Reverse light switch on the transmission.
Fiberglass resin over speaker screen with filler atop that to achieve a paintable surface. The extensions have no torque or stresses upon them so they don't have to be rock solid. The foam is big gap filler and extremely sticky when applied before drying to a solid that takes the shape of the part. Trim fill and finish. I have done so on the door panel pieces and they are solid as can be. The other alternative is low temp welding with materials from the MUGGYWELD company. Mixed results with that route.
congrats!
85 degrees and I'm at the beach at seven lakes85 degrees already. I’m trying to get more of the floorboard cleaned off. Had to remove the drivers side exhaust and found 1/3 of the collector gasket gone. Gonna be a long day. Hoping to spray bomb it tomorrow morning. View attachment 970631
