RM23M9A
Worst, freaking FUEL PUMP removal I think Ive ever done.
Removing the leaky worn out Carter 6903.. How the hell do you get a SOCKET in between left side of pump ad block?!
I had to use a damn pry bar to nearly break the old one to get a thinwall 9/16" on it. Even worse? The damnned Fuel pump rod hole in the block would NOT come out. Luckily I remembered just bump the motor over and eccentric will let up. Pain in the ***. I used to think SB chevy's were tricky? Hell all ya need there is a cold motor and some grease. At least you can get sockets onto those... Jesus!
Freaking HOLLEY! Outboards delayed now till the 26th?!
I guess their Dichromating process is still behind. Hell I've already rebuilt one of the originals in the waiting time. If I get the second baseplate from SixPackPerformance and these dont leak and run right?
I may cancel their crap
