65Fury440
65Fury440, are you saying you are running the springs alone and no assassin bars or calvert bars? If so, the front section of that spring may not be stiff enough to give you the lift you were getting before. I am not familiar enough to be able to say but if they were designed for use with the bars, they may not be ideal without them. There is a reason the SS Springs had the multi leaf front sections set the way they were. They acted a lot like a ladder bar by virtue of their stiffness.
With a pinion snubber and the rear segment unclamped, the rear would raise a lot, maybe 4 or 5 inches, the effect of the rear segment separating.
I kept the snubber on with the new springs to prevent wrap up, it's about 1.5" away from the floor pan and haven't touched at all with the Calvert springs. My plan was to put the springs on then the bars later, it really all needs to be done at once.
Yea 1st and second gear are like driving on ice without the tires being planted. My son took the video on FB, it might be his security settings.Wow, those are marginal for sure. At that trap speed I would expect 1.45 (or close to it) 60' times and 10.90's to 11.0's. Can you PM me a link to your video? It won't come up from your post.
So what are your upgrades this year?
Went to Willwood discs up front, line loc, went from 850 Mighty Demon to the Thumper 1050, put in the Calvert springs, threw away my HF dial back timing light.
I dropped around 120 lbs, and with the new carb got the AFR from mid to high 11s with the Demon to high 12s with the Dominator. The HF timing light was 4 degrees off, so my timing was 40 degrees, I found an old Mac timing light and have the timing at 36 now.
So basically I'm slower this year-
