Use wood 6x6 2 foot pieces when blocking up my car. Had them in 8 different points on the car. Did all the work off a creeper. Had the car 12 inches off the floor. Good luck with the build.
Very Nice progress Mr. Builderguy. Just installed my fenders today, I am having trouble with my gaps, but I will keep on fiddling with them. Unfortunately I dropped a socket on my tablet that I have been using to document the build, should not have left it on the ground where I had been sitting reviewing pics and manuals so no pics to show where I am having trouble. I will take some with my phone and post them to see what you think. Thanks in advanceFinally found the speed nuts and the gaskets (damn dog mush have been out in the garage again).
Front gap is as good as I am going to get it
Right side looking good too
Left side looking good also (no it isn't so there is no pic right now). I will work on that tomorrow, I hope.
This is the original hood pin set that the car was born with, so they are staying (scratches and all). Gives it character.
Thank you for your concern about my safety. I have have been building homes since 1978 using concrete block, poured wall, foam wall modules, and pressure treated lumber as foundation material. Anything can fail, and just about when you say it can't, it does. But according to the rules and standards I have followed for over 40 years I will trust these dry stacked blocks. Here is the standard regarding how much weight a 8"x 8"x 16" concrete block can hold.
Standards. As per standards published in 2003 by ASTM, an international building standards non-profit, all concrete blocks must support at least 1,700 pounds of weight per square inch (PSI).
I think I will be okay.
https://www.hunker.com/13401218/what-is-the-load-bearing-capacity-of-different-sized-concrete-blocks
I've been slow with the updates on my car - I just put my assembly back in the car. You CAN put the engine and K member assembly in with the steering column in place, however, my experience is that the column needs to be pulled backwards about an inch or two so it doesn't get hung up on the box.IIRC there was plenty of room to get the engine past the column.
Hard to say without seeing it in person but if your'e talking about having 4-5 or more spots on the same section of lower quarter i would cut it all off and use the larger repair panel with one horizontal seem. I f you do go with smaller repairs try to not make the corners of your patches square but rounded as this will help a lot with controlling heat/ warpage thrown into the other area of the panel. Go slow ,skip around.question for you all. I only have a quarter panel skin, should I go straight across entire quarter panel where I was already just filling in tiny imperfections to have only 1 BIG seem to deal with, or do "smaller" sections like seen in pic but multiple horizontal and vertical. Obviously after fixing some interior panel work.
+2 on one long seam. That's how I always did it as there were only partial panels back then. Just don't make too much of an overlap.question for you all. I only have a quarter panel skin, should I go straight across entire quarter panel where I was already just filling in tiny imperfections to have only 1 BIG seem to deal with, or do "smaller" sections like seen in pic but multiple horizontal and vertical. Obviously after fixing some interior panel work.
As others have said, one long seam is much easier to work with, just take your time welding so you don't warp the panel.question for you all. I only have a quarter panel skin, should I go straight across entire quarter panel where I was already just filling in tiny imperfections to have only 1 BIG seem to deal with, or do "smaller" sections like seen in pic but multiple horizontal and vertical. Obviously after fixing some interior panel work.
