- 12:29 AM
- Feb 22, 2021
- Roswell, New Mexico
Sealed Power HT-976What type/ brand lifters are you running?. Some can be a little noisy by nature.
Thanks. Any info on how to do this?Check the amount of lifter preload with the current pushrods...... buy new pushrods in a length that will improve that situation if deemed necessary.
One of the old hollow pushrods can be sacrificed to make it an adjustable checking tool.
Hopefully you are right and that is all it was.My bet is he used some pushrods from
a stock 440, and didn't check their
integrity. They were installed being bent.
Just eyeballing them, yes.Are all of the pushrods the same length?
I've read that .515 is about as high as you wantJust a thought. How much lift will a stock 452 head take? Not the springs but the retainer to valve guide boss. That gets over looked a lot and will bend pushrods easily without hurting cranking pressures. I am putting a .505 lift cam on my stock 452's and you have me wondering now.
Checked this with a bore scope. All pistonsCould there be no piston/valve interference that caused this, not saying a full hit but they could be just kissing each other causing a small bind up in the valve train.
Cam is set as it should or (over)advanced?
You said in post #36 that four or five rockers were loose enough that the pushrods may have come out of the lifter.An update:
Pulled the valve covers off and found 16
of the pushrods slightly bent. Haven't
checked the lifters yet as I'm hesitant
about pulling the intake. Going to try and
pull them with a magnet. Four or five rockers
we're loose enough that the pushrods
may have come out of the lifter. Sighting
down the holes in the heads looking at the
lifters, they all seem to be at the same level
in the cups. (none collapsed) Wasn't able
to push any of them down.
Will report on the cam condition when I get
the lifters pulled.
There is oil at the top end.
Thanks all !
An edit: Measured with a tape measure @
9.25 so I am thinking they're a stock 9.315
pushrod.
They didn't, but were the most bent.You said in post #36 that four or five rockers were loose enough that the pushrods may have come out of the lifter.
Not that you could hear over the headerWas the engine making noise the very first time you started it?
Are new pushrods going to bend
while bolting the rocker shafts back on?
tops nice and flat. No dings.
Can't tell from the pic, but it's bent about 1/8".The valves will just open a bit until the spring load collapses the lifter.
After that point, with the lifter on the base circle of the cam....... the pushrod will spin pretty freely.
How about a pic of the most bent pushrod?
