BeepBeepRR
My friends 70 GTX which lost that cam and I swapped engines has an issue of the Sniper screen turning red with "no data" on every part of the dashboard. When it does this it just dumps fuel like the injectors are wide open. It was so bad that it overfilled the oil pan with gas. even Hydro locked the engine.
I drained the oil pan, changed the oil and pulled some plugs turned it over. So upon googling I found a video on Youtube that describes this very well. Apparently I'm sending back a Sniper unit, something is wrong internally or a bad board.
Now here is where I get to thinking. When he lost that cam he said it backfired and popped and then shut down. I am wondering if the Sniper/Fuel dump thinned the oil and caused it to wipe the cam? I assume fuel in an oil pan would evaporate over time and maybe the oil would smell a little gassy. Anyhow below is a video that explains this perfectly.
