Yes, got thier re-inforvement plates and welded them in. After all is done, had the K powder coatedDid you reinforce your k-member?
I did both - had the K member seam welded and gusseted and also installed the Sector support. I did them both at the same time, so I'm not sure which one contributes more, but the car handles nicely.That sector support seems most beneficial for cars that have not had their K members fully welded and gusseted.
Firm FeelFor the rear bar, I went with the 3/4" from Firm Feel, specifically because it is frame hung, so it mounts ABOVE the rear end and axles. I considered Hotchkis like my front bar, but those mount below the rear end.
yes, when I had mine mounted, the suspension shop let me check it out and they drilled mounting holes on the rear frame rails of the unibody to bolt it in.Did you have to drill the holes for the sway bar brackets? I don't recall seeing holes there.
No, just for where it mounted to the bodyDid you have to drill the holes for the sway bar brackets? I don't recall seeing holes there.
it's only a few holes drilled on each side and no big deal. It's not enough to compromise any strength and the ends where the holes are have two large U-shaped support brackets so after install it's plenty strong. It was easier using the lift at the shop and they let me watch while they did it. It took some careful angling to snake it in up over the rear end, but they were able to get it installed without removing anything else, no rear end removal or anything. I took it to a shop that specializes in suspension and works on both classic older as well as new cars, but they had never installed one of these on an old mopar before.I like that the bar is mounted high, but I have to admit modifying the subframe scares me a little. I'd want to take this job to someone who's done a few of them.
Stock rear sway bar fits belowFor the rear bar, I went with the 3/4" from Firm Feel, specifically because it is frame hung, so it mounts ABOVE the rear end and axles. I considered Hotchkis like my front bar, but those mount below the rear end.
72 and laters already have the holes for the brackets on frame rail. Stock brackets and location can be used if adding the rear sway bar
That's how FF designs it, same as mineFound this Firm Feel sway bar installed on user BigFlo's car -
This looks like it is mounted same as the one in my previous post - is it possible 68 Sport Satellite's bar is not installed correctly? His sway bar brackets are right up next to the bump stops.
that photo I posted is not of my car. It's an E-body, but the mounting location on my 68 Satellite is in the same general location.Found this Firm Feel sway bar installed on user BigFlo's car -
yours is same as the photo of BigFlo's car or like the one of the E-body I posted?That's how FF designs it, same as mine
