Hey all,
Sorry for the delay in following up with this. I have been out of town and this is my first weekend back and under the car.
I just finished wrapping DEI Fireline around the fuel line. I also installed a vapor separator filter and was running the return line. Got almost all the way to the tank when I noticed, just above the axel where the fuel line follows the contour of the body to the tank, a !@#$!@ kink in the line. It looks like it has been there for ages. Covered in grease and undercoating, the kink almost shuts off the fuel flow. My guess is the original 318 with a 500CFM didn't need as much fuel and so no problem. But the 440 with a 750CFM is fine at idle but under load, the kink is restricting the fuel.
I know it was vapor locking as well so I will leave the filter as it is. I may take out the vapor separator and go back to a simple inline filter, fix the kink and see how I get on. Curiosity is driving this more than anything. I want to know how the DEI fire line helps with the heating fuel.
Lots of great advice here.
Here are some pics of the fuel line today. Last pic shows the crushed line, and it looks like maybe the old exhaust did it. I think I know how it happened, but I have to go back 46 years. That was the side when, as a 17-yr old kid, I had single exhaust and, hitting a 90 deg corner on a Puyallup farm road at 55 MPH, I blew the bead off my stupidly wide rimed tires. The tire blew, dropped the rear passenger side axel into the gravel, destroyed the rims and stretched the leaf spring by an inch. I didn't realize the exhaust moved up that far and crushed the line. In hindsight, I was lucky I didn't roll my Charger.
The crushed line is about 15" from the tank. Do you think it would be OK if I just cut the pinch out and ran a longer fuel line to the tank? Or should I replace the entire line?
