What did you do to your Mopar today?
After working out the last few gremlins, finally drove the car 20 miles home from the shop!
Blocking off guide coat.
96 degrees F ambient, but 105 degrees F at the car due to the concrete and metal around. At least it dries fast.
50mi round trip in the Hemi Satellite to a Hagerty open house at a Hagerty storage location really close to Spring/Fall Fling
Cleaning more parts for the windows prior to install.
Painted the new pump and housing... I'll be putting that back on the block today.
I got the areas of the Charger gravel guarded and the core support blacked out last weekend. Next step is to mask it, take it to work and start painting
More primer, black this time. Might be the last coats after some more block sanding, etc.
Putting on the red paint on the two-tone red/white on my 57 Dodge Coronet. Doors and fenders shot today. Almost done!
It's been a long and winding road.
YIKES!!
No way!!
So, out with the old rubber incorrect Hurst boot, in with one my daughter stitched up for me from marine vinyl......
Today we worked on my buddy Barry's GTX - we moved it to my house and (likely temporarily) installed the K member assembly.
Here is the flat bed to tow the car .9 miles to my house.
Once in the garage, we moved the K member assembly under the car.
Closer...
Closer...
...and in!
Here is a shot under the car.
Now we can figure out the positioning of some wiring, a fuel pressure regulator and a couple of other items. The assembly will likely come out one more time so we can install or get to needed areas, but there is a small chance this is permanent. We'll see as we make more progress.
Closer...
Closer...
...and in!
That's the way to do it... Get it all in one go!
That's how I did mine just recently. I didn't have a lift though... I used my rotisserie for the lifting and lowering. A little more tedious perhaps, but it got the job done just the same.
Not alot, but something. Put in the missing splash shields on my convertible, got them at Carlisle.
