So i got the hemi fired up on the run stand a couple weeks ago. I had a rear main seal leak so back on the engine stand to pull the pan and repair seal. had a small leak on the back passenger head oil return galley so i pulled the intake to pull the head to seal around oil returns. I was surprised to see how much oil was in all intake ports with exception of #8 I used prussian blue on the intake gaskets and had good contact around all ports. Wondering now if the intake gasket is still leaking here’s some pics of the ports after i wiped them out some. also used prussian blue again this time without the gaskets in place. also the new plugs were oil fouled really bad.
