- 7:13 PM
- Jul 9, 2019
- Modesto California
I lost a Huges cam several years ago, before all these issues with cam and lifter quality. When I got the cam and read the spring specs, I called Hughes and flat told them this cam will never live at these spring pressures, they assured me it would work just fine. Cam went flat in three passes on the track. After break in, with weak springs. Of course, all the excuses were used first one was not breaking it in right. I told him I was an engine instructor at a technical college, and I had 40 witnesses about the break-in because I did the engine in front of the class. So I sent the cam to Hughes they said all the surviving lobes and lifters had correct break-in markings. Never got a dime from Hughes. metal in the bearings, metal in the skirts of the pistons etc. Never bought another cam from Hughes, never bought another flat tappet cam for my race car. Today I almost will not use a flat tappet camshaft on a street engine, I tell my customers just buy a hydraulic roller and be done with it. OEM have not used flat tappet cams since the 1990's no need for oil with zinc in it, just drive and enjoy. I find you can get more lift with a shorter duration, makes a very good running street engine that way, lots of low end torque with decent idle vacuum.I lost a Hughes cam and lifters to what Hughes described as poor lifter bore alignment of the cylinder block. I had it bushed and rebored on a Rotler machine (had trouble getting blueprint specs to use) and all is well for many years now. Hughes told me they believed the production fixtures that Chrysler was using were probably worn out but, the tolerances were acceptable for production cams and lifers. Not so with higher lift and stouter valve springs. That made sense to me. The further back in the block I went with lifter inspection, the worse the lifter damage.
Mike
Well said.I lost a Huges cam several years ago, before all these issues with cam and lifter quality. When I got the cam and read the spring specs, I called Hughes and flat told them this cam will never live at these spring pressures, they assured me it would work just fine. Cam went flat in three passes on the track. After break in, with weak springs. Of course, all the excuses were used first one was not breaking it in right. I told him I was an engine instructor at a technical college, and I had 40 witnesses about the break-in because I did the engine in front of the class. So I sent the cam to Hughes they said all the surviving lobes and lifters had correct break-in markings. Never got a dime from Hughes. metal in the bearings, metal in the skirts of the pistons etc. Never bought another cam from Hughes, never bought another flat tappet cam for my race car. Today I almost will not use a flat tappet camshaft on a street engine, I tell my customers just buy a hydraulic roller and be done with it. OEM have not used flat tappet cams since the 1990's no need for oil with zinc in it, just drive and enjoy. I find you can get more lift with a shorter duration, makes a very good running street engine that way, lots of low end torque with decent idle vacuum.
Hughes used to use Engle cams. I talked to Engle about Hughes spring pressures some years back and they thought the pressures were excessive. I like Engles and use them. But not with Hughes springs.I lost a Huges cam several years ago, before all these issues with cam and lifter quality. When I got the cam and read the spring specs, I called Hughes and flat told them this cam will never live at these spring pressures, they assured me it would work just fine. Cam went flat in three passes on the track. After break in, with weak springs. Of course, all the excuses were used first one was not breaking it in right. I told him I was an engine instructor at a technical college, and I had 40 witnesses about the break-in because I did the engine in front of the class. So I sent the cam to Hughes they said all the surviving lobes and lifters had correct break-in markings. Never got a dime from Hughes. metal in the bearings, metal in the skirts of the pistons etc. Never bought another cam from Hughes, never bought another flat tappet cam for my race car. Today I almost will not use a flat tappet camshaft on a street engine, I tell my customers just buy a hydraulic roller and be done with it. OEM have not used flat tappet cams since the 1990's no need for oil with zinc in it, just drive and enjoy. I find you can get more lift with a shorter duration, makes a very good running street engine that way, lots of low end torque with decent idle vacuum.
Like the Isky E4 in my lil' 273. It's a solid lifter stick just a bit over stock specs. They recommend a dual spring which I feel is overkill.Hughes used to use Engle cams. I talked to Engle about Hughes spring pressures some years back and they thought the pressures were excessive. I like Engles and use them. But not with Hughes springs.
They machined them properly back then. Somewhere along the line the specs have been lost or as a cost saving measure, a different procedure is being used. My last flat tappet cam is my last one. I think hydraulic roller is where it's at.Still don't understand that car manufactories used flat tappet cams for years and never had a lot of problems and they didn't have machine technology like we have today. To bad no one has a new old cam and lifters from back then , be interesting to check the cam and lifter machining and metal quality .
I'm curious about this whole thing.They machined them properly back then. Somewhere along the line the specs have been lost or as a cost saving measure, a different procedure is being used. My last flat tappet cam is my last one. I think hydraulic roller is where it's at.
(and I don't know anything
about any "accents" - sounds normal to me).
And yet after having lived most of my life in California I still get asked about my speech patterns having spent my earliest childhood in Mississippi and Texas...Machining probably was ok but not spot on back then , they made thousands of motors with lifter bore misalignment not right on plus other like cam bore and crank bore alignment etc. and they survive for many ,many miles . If the flat tappet cams and lifters isn't machined right nowadays wonder about the roller cams and tappets if they are machined right ? I heard they have problems too plus you got more variables , cam button , dist.gear and other parts that goes with roller cam set up Back then they made it work , today sort of .They machined them properly back then. Somewhere along the line the specs have been lost or as a cost saving measure, a different procedure is being used. My last flat tappet cam is my last one. I think hydraulic roller is where it's at.
